Gauge sender question
Old Dec 23, 2005 | 10:12 AM
hamilton71801's Avatar
I am in the process of the putting the new style Diprical gauges (fuel pressure, trans, pyro) on my sig truck. My question is where would be the best place to put the trans sender-in the pan or right before the heat exchanger? I'm afraid if I pull the pan to drill out for the sender I will be tempted to spend more money for a heavy duty valve body and a shift kit. I am slowly getting the truck ready for a Edge EZ or Van Aiken box. My thinking is I can put the sender on the trans line for now then later when I have the money for the trans upgrade I can put another one in the pan and plug the one in the line. What would ya'll do?
Old Dec 23, 2005 | 10:19 AM
VADSLRAM's Avatar
I would tap the line to the cooler. That way there is less permenant mods and you get a flow of fluid past the sender. If you tap the pan where there is a stagnant (relatively) area the temp would be off.
piperca
Feb 22, 2005 02:45 PM
getblown5.9
19
Feb 10, 2005 08:21 PM
DaNuGuy
Jun 22, 2004 08:44 PM
pancowboy
Jan 10, 2004 04:41 PM
latitud_rt
Feb 28, 2003 09:20 PM
