gauge pod ?
Old Jun 9, 2005 | 01:36 PM
fordsux8269's Avatar
gauge pod ?
I just recieved my gauge pod from DPP today and i ordered the full a pillar 3 gauge pod and it says that it just screws to the old a pilar. And i was thinking that it would be a full replacement pillar with new clips so that i could just throw the old one in the trash seeing how all the clips are broke off and it is held on with a screw right now. Is there anyone out there who make a full pillar replacement?
Old Jun 10, 2005 | 09:38 AM
Mark Craig's Avatar
fordsux8269,
All of the A pillars for all but the 2003+ trucks re use the stock pillar behind the replacement one. Folks have tried to not use the stock one behind the new one but it usually doesn't work out to well.
Mark @ DPPI
Old Jun 10, 2005 | 09:54 AM
Beast2B's Avatar
skip the screws and get some double sided tape or velcro and you don't have to mangle the stock unit
Old Jun 10, 2005 | 11:17 AM
firestorm's Avatar
I removed my stock one, put the new one (3 gauge) in place, and drilled one small hole about 6" down from the top and at a 45* angle from the windshield. I used a 5/16 bit by hand ( be careful not to cut out too much), to create a taper in the outside of the new pillar, to allow the use of a flush mount screw. I then got, I believe, a #6 x 2 1/4" wood screw and painted it the same color as the pillar. Put the pillar in place, and hold it there with the single screw.
Old Jun 10, 2005 | 12:52 PM
Mike D's Avatar
You can use just the gauge pod.
I use these little bumper stops to hold the pod in place.
Old Jun 10, 2005 | 06:37 PM
Ok so how did you use jsut the bump stops to hold the pod on
Old Jun 10, 2005 | 08:51 PM
dezlsmkr's Avatar
I messed up my stock pillar to broke the clips so i said forget it and just cut holes in my stcok pillar for all the wires hoses ect.. And took a screw and just screwed my stock pillar on then put the gauge pod on like it is supposed to go and cant tell a thing.
Old Jun 13, 2005 | 02:42 PM
Mike D's Avatar
The door seal hold the pod on one side, while the stops hold the pod firm in place on the other side...
BrokeSolid
21
Feb 3, 2009 09:36 AM
whitebuffalo
Nov 3, 2006 10:53 AM
scarecrow
Mar 9, 2006 08:12 PM
Bad Ramer Jamer
Dec 1, 2005 02:30 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
