Gauge Install Electrical Question
Greetings, all. I am about to install my A pillar and Autometer EGT & boost gauges, and a head scratcher has come up.<br><br>Where's the best place to tap in for lights power and the EGT gauge power source? I called a stereo shop, and their only suggestion was to tap into a power source with a crimp connector-ughh...<br><br>There has to be a better way to get power up to the A pillar, and I thought I'd read somewhere about a fuse connector/tap that worked well. Any suggestions?<br><br>Thanks in advance,<br>Joe
Re:Gauge Install Electrical Question
For my gauge power I put a fuse tap into position #16 in the fuse box. That is key on power and was previously unused.<br><br>As for the gauge lights, I tapped into the wire coming off the back of the headlight switch that supplies light to the rest of the cluster. This way my gauges dim along with the rest of the dash.
napa for the taps.. you get like 4 for a couple bucks. Tap the #5 so you can dim the lights on the gauges... at least that's what I did! ;D<br><br>Tony
[quote author=Commatoze link=board=7;threadid=5559;start=0#49249 date=1033949336]<br>Also, Painless Performance make some nice fuse blocks for adding electrical accessories. I think Geno's carries them.<br><br>-Tom-<br>[/quote]<br><br>Ahhh yes, I should've mentioned that! I just hooked up my 4 + 3 a few days ago! I love it! ;D
ado2b1
Jul 6, 2007 10:27 PM
scarecrow
Apr 17, 2006 06:35 PM
staarma
Feb 9, 2006 10:10 PM
schorb
Aug 19, 2004 08:25 AM
Diesel Dave
Jan 3, 2003 03:37 PM
