Gas 3/4 Ton Lift??
Old May 16, 2006 | 05:25 PM
STACKED's Avatar
Gas 3/4 Ton Lift??
will this work for a diesel? i found one with springs and all for cheap, but i need to know if it will hold the weight.
Old May 16, 2006 | 06:37 PM
Rattlerattle's Avatar
Check with whoever makes the lift.
Old May 16, 2006 | 07:06 PM
phox_mulder's Avatar
I doubt it.
Rear springs aren't the same size.
If the front is replacement springs, then no way will it hold, if it is a spacer then it might work.
phox
Old May 16, 2006 | 11:23 PM
Cowhand's Avatar
Different spring rate....difference in sprung weight is probably 300lbs or better.
And phox is right, IIRC rear springs on a gasser are 2.5" vs. 3" on a diesel....
Old May 17, 2006 | 01:45 AM
STACKED's Avatar
no sorry i meant fronts
Old May 17, 2006 | 09:20 AM
Gotlift01's Avatar
Yeah fronts have a different spring rate.......you'd be better off to go with a spacer then those springs.
~Nick
Old May 17, 2006 | 09:54 AM
whitebuffalo's Avatar
if its off a v-10 gasser it should work. if its off the 360 it will not. most of the kits ive seen use the same springs for the v-10 or the ctd.
John H
Oct 14, 2004 06:46 PM
dieselnewbie
Mar 16, 2004 07:15 PM
The Roamer
Dec 15, 2003 07:40 PM
dealseeker
24
Dec 18, 2002 10:39 AM
dhe9
Oct 28, 2002 04:57 PM
