Fuel Tank
Old Feb 23, 2003 | 11:32 PM
cfm3110's Avatar
Fuel Tank
Any suggestions on an auxilary fuel tank for my truck?? What brand, how much, good idea, bad idea, etc. Thanks for the help
Old Feb 24, 2003 | 04:39 AM
pappyman's Avatar
Re:Fuel Tank
Lot's of options to choose from do you want a in bed type ?? or a underbed type ?? a big capacity tank ??
Northern tool has some tool box tanks along with alot of farm stores that carry aux tanks.....I have a in bed 100 gal tank that I bought from TSC farm store.....heres a link to give you some idea's about tanks
http://www.transferflow.com/html/toolbox_tanks_0.html
http://www.northerntool.com
Old Feb 24, 2003 | 11:26 AM
cfm3110's Avatar
Re:Fuel Tank
thanks pappyman. Why are the transferlfow so much more expensive than the northern tool? And where would i get an underbody type??
Old Feb 24, 2003 | 01:13 PM
butchera's Avatar
Re:Fuel Tank
The Northern Tool one's are just the tank. You have to do all the plumbing. <br><br>The Transferflow comes as a kit. All the parts, pumps, hoses, etc. Also, the transferflow has a fuel management system with it. It automatically transfers fuel for you so you don't have to play with a switch.<br><br>American tank http://www.auxtank.com has a system that is just like the one in a phurd I had. You flip a switch and the guage reads the aux tank and flips a valve.<br><br>As for the under body types, transferflow has those also along with Aero Tanks http://www.aeortanks.com.<br><br><br>Hope this helps as I'm trying to decide whick way I'm going also.<br><br>
Old Feb 24, 2003 | 03:53 PM
dsljunkie's Avatar
Re:Fuel Tank
I just happen to be selling my 78gal ATTA wedge-see over tank. If your interested PM me and I'll send you some pictures or whatever. Maybe we could work a deal since you are a fellow DTR'r .<br><br> Wheels
Old Feb 24, 2003 | 04:33 PM
cfm3110's Avatar
Re:Fuel Tank
How much would all of the &quot;plumbing&quot; cost?? would it be worth doing that myself? (Keep in mind im a BROKE college student )
Old Feb 24, 2003 | 09:32 PM
pappyman's Avatar
Re:Fuel Tank
These tanks are not cheap....my 100 gal tank was mounted in the bed with a simple gate valve on the bottom out port and I just plumbed it into my tank filler tube....this works as long as you dont forget to turn it off before the truck tank is full....and fuel will gel in these tanks when its cold unless you have a blend or use anti-gel<br><br>It takes awhile to get a pay back for a $500.00 tank investment but have found its nice to carry 135 gals of fuel when making a 2500 mile trip I have found buying fuel in a state with cheaper fuel prices can save me .40 cents a gal
Old Feb 24, 2003 | 10:15 PM
cfm3110's Avatar
Re:Fuel Tank
how does the electronic sending unit that some people use work? and how much would it cost to add that myself?
Old Feb 25, 2003 | 01:56 PM
FiverBob's Avatar
Re:Fuel Tank
[quote author=cfm3110 link=board=7;threadid=11395;start=0#108737 date=1046146552]<br>how does the electronic sending unit that some people use work? and how much would it cost to add that myself?<br>[/quote]<br><br>I have an RDS tank/tool box combo. It is the lowboy set up for dragging the fiver. Tank is 45 gallon. Nice quality diamond plate, baffled, the whole enchilada. It runs about $600. You can either install it gravity feed which is quite easily done. Or, you can install it with a switch over device. RDS sells that install kit for $240. You could then install it yourself. Their switch over is similar to that used in most motorhomes. You draw on which ever tank is selected. The fuel gauge of the truck will read the tank selected (if you chose to hook it up that way). When you switch over, the selected tank then starts drawing down and the guage reads the selected tank.<br><br>RDS Technologies - - Ask for Bobby - - 1-850-584-6898<br><br>If you wish to see the installation, check out my pics in the member picture section. FiverBob's White Ghost<br>
Old Feb 25, 2003 | 04:09 PM
cfm3110's Avatar
Re:Fuel Tank
Fiverbob, thanks i called and talked to Ray(Bobby wasnt in) and im going to try and justify buying one <br>any other help would be appreciated
Old Feb 26, 2003 | 06:30 AM
bobgay's Avatar
Re:Fuel Tank
FiverBob:<br>I had the 115 gallon RDS tank installed last week. They installed the electric switch over valve, which works fine, but they could not get the fuel guage to work on the auxilliary tank. Apparently the sending unit voltage does not match up with the 03 Dodge guage. They are still talking with the supplier and other installers, trying to get something that will work.<br>I'm wondering if you were able to hook your tank to a guage?<br>BobbyG
Old Feb 26, 2003 | 11:37 AM
cfm3110's Avatar
Re:Fuel Tank
where would i get everything i need for the electric switch over and how much would it cost?
Old Feb 26, 2003 | 04:19 PM
FiverBob's Avatar
Re:Fuel Tank
[quote author=cfm3110 link=board=7;threadid=11395;start=0#109378 date=1046281031]<br>where would i get everything i need for the electric switch over and how much would it cost?<br>[/quote]<br><br>Ray or Bobby can guide you on that. You can buy it directly from RDS. <br><br>Bobby G. <br>I have been slothful in completing the install on the switchover. I am still running on the gravity feed. Soon :P :P<br>Glad to know about the fuel guage. I was thinking of running by the plant and have them complete it. I have to go up that way in a couple weeks. Have it done right. Maybe they will have the problem worked out by then.<br><br>Bob
Stamey
Jun 27, 2008 02:04 PM
ramsport59
MDDTR #33
Feb 21, 2008 04:15 PM
Mike M
Jun 5, 2006 11:38 AM
ddestruel
Mar 26, 2006 01:54 AM
Toby
Apr 6, 2005 12:31 PM
