fuel systems?
I had the older Wildcat Max flow (Scottys earlier version) and went from pulling FP down to around 7...to not being able to go below 11 at WOT.
Have heard Scottys new system is better....so assuming your pump is in good shape...should never see single digits again until you get over 425 HP +/-.
RJ
RJ
I've got my Scotty's system on order too (ordered through the store here
, UPS says its on its way
If you check out the install instructions at Scotty's Page and scroll to the very bottom there are before and after fuel pressure comparisons.
~Rob
). If you check out the install instructions at Scotty's Page and scroll to the very bottom there are before and after fuel pressure comparisons.
~Rob
o and another side note to the pressures on the scottys page were it is talking about the pressures at 15 psi crusing 65 . this truck is running 315s and the trucks speedo is off . from what i hear . at least thats what the nice chp officer has told me
spooling
Apr 26, 2008 03:06 AM
Diesel Dave
15
Mar 18, 2005 10:06 AM
