Fuel system upgrades
Old Apr 1, 2003 | 05:46 AM
DarrellB's Avatar
What's a good setup to go with? I'm still running my factory lift pump and it's still putting out 7 psi at WOT but I'm in need of a little boost in Fuel Pressure before going any farther with my mods.<br><br>I need some input on what others have used and what works good. I know about the PE 4200 but it's a tad bit on the $$$$$$ side for this old farm boy. : I just need something to help the stock lift pump out. Some sort of Pusher or something.<br><br>Any help would be appritiated. 8)<br><br>Thanks<br>DB
Old Apr 1, 2003 | 06:48 AM
hellotbone's Avatar
Re:Fuel system upgrades
Call Rod at wildcat I believe he has somthing int he works. :
Old Apr 1, 2003 | 07:06 AM
bulthisl's Avatar
The Holley Black pump is a good one.<br>And as Jamie said Rod has a good set up with that pump.<br>I hear he has put together a kit for your truck with everything you need.<br><br> : Eddie : 8)
Old Apr 1, 2003 | 10:29 AM
BigBlue's Avatar
I like my Holley Black. 16.6 at idle and 13 at WOT with pump wire. The PE4200 is also a good pump.
Old Apr 1, 2003 | 05:32 PM
Diesel Freak's Avatar
an inexpensive and reliable BOMB is to just move the OEM lift pump back by the fuel tank. Replace all the Banjo fittings with -6an fittings and 3/8 fuel line.<br><br>This is what I am running...14-15 psi at idle, 13 psi at 70 MPH, and 9 psi WOT.<br><br>this is with DD3's and a timing box.
Old Apr 1, 2003 | 09:59 PM
DarrellB's Avatar
[quote author=Gonzo link=board=7;threadid=13017;start=0#123210 date=1049240678]<br>Give Rod a call, he has something that will work for ya. Don't call after 3am, he's busy with bubbles the blue sheep. ;D<br>[/quote]<br><br>&quot;Bubble the Blue Sheep&quot; <br><br>That's kinda of scary. [undecided]<br><br>Maybe if I spend some money he can get Bubble's something nice. <br><br>Thanks Guys<br>DB
Ace
Jan 2, 2009 02:02 PM
dodgehotshot01
Jan 1, 2009 01:21 PM
Knifeman
Aug 13, 2007 07:17 PM
Igor
Dec 19, 2005 06:29 PM
hellotbone
Aug 3, 2003 08:15 PM
