Wildcat Fuel System Upgrades
Old Jul 31, 2003 | 07:06 PM
hellotbone's Avatar
I just finished the installation and it was pretty easy even with minimal destructions.
Fuel pressure is up 2PSI at idle I was 13 now 15 steady.
Cruise don't get below 13.5 and WOT 7PSI + so Im very happy I was pulling my FP to 3 or less before the kit at WOT with my comp on 5 now I can't get below 7 so the kit works for anyone on the fence.
What I did
First day I installed the connection from the outlet to the VP44 chich is really easy then today I installed the filter inlet and the main fuel to the lift pump connection. Both parts combined would take up about 1.5 hours taking it easy so its no big deal. After each connection I started the truck to keep the prime up. The hardest one is the LP outlet to the cannister inlet I unhooked the cannister took about 1' of hose and connected it to the 90's then installed it then put the cannister back on. The inlet for the LP is easy just remove the old one put the barbed fitting on I would shove the hose on before installing the fitting. Then under the truck you go on mine it was the inside line closest to the frame that was the main line took the x acto knife and sliced the line came right off the hose. Cut the braised rubberline to fit and I was off. Anyone looking to up there FP this is a great way to do it. ;D
Old Jul 31, 2003 | 09:40 PM
StillPlowN's Avatar
Re:Wildcat Fuel System Upgrades
Jamie,
Did you use the PE 4200 that Rod has, or did you just use his line kit. At any rate sounds like a nice setup and something I'll have to check into in the near future.
Old Jul 31, 2003 | 10:59 PM
StakeMan's Avatar
I recently installed the same fuel line kit and am in the process of finishing the article for the DTR. ;D
Old Aug 1, 2003 | 01:02 AM
DarrellB's Avatar
[quote author=StakeMan link=board=7;threadid=17811;start=0#msg166760 date=1059710364]
[/quote]
Well hurry up so I can buy mine. ;D ;D ;D
DB
Old Aug 1, 2003 | 06:06 AM
hellotbone's Avatar
[quote author=StillPlow'n link=board=7;threadid=17811;start=0#msg166721 date=1059705620]
Jamie,
[/quote]
Still using the stock LP! Thats why I know the kit really works! Like I posted I was pulling less then 3PSI WOT before now I'm a steady 7+ after the installation.
Old Aug 2, 2003 | 04:03 PM
hellotbone's Avatar
For some reason today Im running about 1 1/2 PSI more then writing this I wonder why that is but hey I ain't complaining.
Old Aug 3, 2003 | 05:48 PM
ejb's Avatar
ejb
What are you talking about?A pusher pump or something?
Old Aug 3, 2003 | 08:15 PM
JMull's Avatar
[quote author=ejb link=board=7;threadid=17811;start=0#msg167707 date=1059950917]
[/quote]
It's a fuel line upgrade that Wildcat Diesel offers. The idea is that the pump isn't as much of a problem as the lines and banjo fittings. With this kit the stock fuel pump is retained. As Jamie has seen, fuel pressure goes up, but I'm sure that volume also is increased. trying to get all that fuel through a little hole in a banjo bolt is very restrictive.
I hope this helps clear things up for you.
John
HOHN
23
Dec 13, 2004 10:33 AM
gsdog1
Jan 14, 2004 01:35 PM
GatorRam
Oct 9, 2003 01:57 AM
Jack Thorpe
Site News
Oct 5, 2003 01:17 PM
Jack Thorpe
25
Sep 11, 2003 01:21 PM
