fuel system
Old Sep 17, 2006 | 08:01 AM
99blackrig's Avatar
fuel system
I am considering using an areomotive pump that I have that flows 150gph at 18 to 20 psi, to eliminate my carter. I figured I could get all the brass fittings at my local hardware store and the fuel lines at my local automotive store.
What size fuel lines should I run? I was thinking 3/8 id, or should I go 1/2 id.
Is 18 to 20 psi going to be to high for the vp44?
Do you need to change the return side? If so what size line?
Should I run 3/8 to the filter then 1/2 to the pump?
Do most of you guys relocate and use a new style of filter?
Sorry for all the questions but I already have the pump and I think I could do everything for about $50.00
Old Sep 17, 2006 | 08:46 AM
blackdiesel's Avatar
Registered
3/8 is plenty, and 18-20 psi is the sweet spot!
Old Sep 17, 2006 | 08:55 AM
99blackrig's Avatar
Do you think the stock pick up will be able to handle 160 gallons per hour.?
Old Sep 17, 2006 | 09:10 AM
RowJ's Avatar
The stock pick up handles 150 gph from a FASS with no problems.... so Yes.
18-20 psi is not too high. MY newer FASS spring runs 18-19 psi and I like it better than the previous 14-15 spring, but I can't give you solid data as to why. No downside I know of below 22 psi.
FASS uses 3/8" lines which is more than enough. The high flow systems out there use 1/2" but I believe that is just to provide greater fuel reservoir for the smaller Carter pumps and would not be needed with your Aeromotive 150.
RJ
Old Sep 17, 2006 | 09:49 AM
99blackrig's Avatar
Thanks. Do you have to drop the tank to change the lines?
Old Sep 18, 2006 | 07:16 AM
RowJ's Avatar
Not if you have small enough hands
Look on FASS' web site for install instructions. They cover the subject well.
http://www.dieselpp.com/
RJ
RiverRat2
Oct 15, 2019 10:59 AM
ado2b1
Jul 6, 2007 09:35 PM
DISTURBED
Mar 11, 2007 09:14 AM
chucktownsend5
Mar 8, 2005 08:21 PM
