fuel pumps
fuel pumps
i interested in getting a new lift pump i really like the raptor anyone running this? i not sure if i should get the airdog or raptor any ideas and where is good place to get one i see tham all over for like 500 any ideas thanks
I like my FASS alot. AirDog is a good one as well.
DTR store sells em both.
If I were you, I'd get the bigger of either. 150 or 165 gph
Dont HAVE to have the air and water seperator, but get the 150+ GPH so you dont have to upgrade down the road if you get bigger mods. JMO
My Airdog II 165 is great. I put my Edge upto 5x5 and put it to the floor. My fuel pressure never got below 15. I only had to back out if it due to EGTs. Also the fact that I can adjust the pressure is a plus. The only draw back is that it is double what a raptor will cost you but I believe it is worth the money.
The holley blue has worked great for me...despite all that say not to use them. I have an inline pre-filter spin-on, the psi is regulated and it never drops below 15psi. The setup was easy to install and about $150. Like stated above, figure out what you're going to use the truck for and build/budget accordingly.
JJK98CTD
Mar 29, 2009 10:45 AM
May 31, 2003 03:28 PM
