fuel pressure light???
Old Jan 14, 2009 | 03:54 PM
dahla's Avatar
i am looking @ putting on a fuel pressure light does anybody know anything about these is there good ones bad ones etc.... was looking at the one would it be sufficent???
http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
Old Jan 14, 2009 | 04:12 PM
Fishin2Deep4U's Avatar
They are work using the same principle. Just a pressure switch like an oil pressure switch that turns on the light.
IMO, you are far better off with a gauge.
Dave
Old Jan 14, 2009 | 04:29 PM
dahla's Avatar
i'm not planning on going wild w/ my truck and and just looking for something simple that will let me know if fuel pressure is low don't want to ruin my VP44 if ya know what i mean
Old Jan 14, 2009 | 04:36 PM
tonycamacho's Avatar
I install BD fuel pressure light while in the states last summer. I am glad I did because it probally saved my injection pump when my lift pump started to fail. I also screwed in a cheap pressure gage into my fuel filter canister housing which helps to verify the pressure and light. I am now waiting for my Air Dog 100 pump to arrive and screw those stock pump replacements. The pump that failed was the second one I had installed.
Tony
Old Jan 14, 2009 | 05:11 PM
Flatbed24v's Avatar
I light will only tell you that is bad but a gauge you can watch to see what pressure it runs at idle, driving, and wot. You also will be able to tell if the pump is on it's way out from drop in pressure and slow build up. I put gauges on first and in stock form I could pull my new stock pump down to the danger zone. no matter if you stay stock or go all out u should at least get a fuel pressure gauge, but if you just stick with the idiot light and if it comes on a lot I would change out the pump to be safe but you won't know if it is bad with out a gauge or your ip goes out. Just my two cents
Old Jan 14, 2009 | 05:27 PM
Dr. Evil's Avatar
Again, you are much better off with a guage and it doesnt matter if you are stock or wild. A gauge lets you see trends in pressure. An idiot light is just that - an idiot light.
Old Jan 14, 2009 | 06:10 PM
dahla's Avatar
i have a quad recon gauge does anybody know if and when the fuel pressure kit will be availible for it i know it is supposed to have the capability to monitor it but can't find the kit for it that is y i was looking at getting the light?
Old Jan 14, 2009 | 06:13 PM
Flatbed24v's Avatar
email quad, there was a thread that he started about three weeks ago on here, saying that the fuel pressure kits are ready
Old Jan 14, 2009 | 06:19 PM
dahla's Avatar
i called them they said they were availible for the commanders but not for the recon yet i guess?? probably the same thing i would think maybe not though?
Old Jan 14, 2009 | 06:49 PM
dahla's Avatar
what gauge would u guys suggest i'd rather not spend much over $100, and i'd rather not run fuel into the cab is that possible the electric gauges i've found are $150-$200 plus i would have to buy a pod yet for it??
Old Jan 14, 2009 | 07:12 PM
Get a mechanical gauge lit with a good isolator. Fuel will stay under hood and it's glycol into the cab.
Dave
Old Jan 14, 2009 | 07:18 PM
dahla's Avatar
k, where can i find something like that and how much $$$ am i looking at to get this set up???, kind of new to the game is there a kit i can get or something of that sort for it? something w/ good instructions
Old Jan 15, 2009 | 01:41 AM
Dr. Evil's Avatar
www.vulcanperformance.com has what you are looking for -
http://www.vulcanperformance.com/ISS...it-p/issfp.htm
as does most performance diesel suppliers/shops.
I run fuel into the cab (have for 6 years now) - its cheap, accurate and troublefree - but hey, its your truck so install whatever you want on it.
Old Jan 15, 2009 | 04:11 AM
Just a note, the above kit does not run fuel into the cab. It uses a proprietary isolator and keeps the fluids separated. Fuel under the hood and glycol into the cab.
Dave
Old Jan 15, 2009 | 04:45 AM
98whitelightnin's Avatar
If you dont want to spen much money look at this.
http://www.genosgarage.com/prodinfo....ber=WM-FPKT-30
