Fuel Pressure
Old Jan 31, 2010 | 12:51 PM
Derek Edgar's Avatar
Fuel Pressure
2000 3500, 2wd, 5-speed, K&N intake, 280hp injectors, 4in exhaust, Quadzilla - 60-90-120hp tuner.
Is the stock lifter pump giving me enough fuel to injector pump?
How much pressure is needed?
If I need more fuel pressure what is the most economical route to take?
Derek
Old Jan 31, 2010 | 01:09 PM
mogacam's Avatar
No way. Your sgoud upgrade to a airdog or raptor 150.
Old Jan 31, 2010 | 01:47 PM
I think im at around 420hp total.........
same answer?
Old Jan 31, 2010 | 05:08 PM
98.5Hotrod's Avatar
You need a better pump. you may have damaged your VP44 already.
Old Jan 31, 2010 | 07:59 PM
Any suggestions?
Old Feb 1, 2010 | 10:09 AM
matthais's Avatar
airdog df165
Old Feb 3, 2010 | 11:48 AM
supr's Avatar
You may want to look at a big line kit from Vulcan. They can also recoomend pump options.
I would certaily get an FP gauge if you do not have one.
You should run 9-15 under most circumstances, 5 psi minimum.
Boost & Pyro are recommended for BOMERS. Geno's is a good place for gauges.
How many miles on the VP?
30-100k seems the normal life of most. Some get lucky & go 200-300k.
Go figure!
Old Feb 6, 2010 | 08:04 AM
I lost the original VP at 100K. got 80k on this one. I've been changing the lift pump about every 30k. But I now have added the injectors and Quadzilla box.
A new clutch is coming soon.
Already have boost and pyro gauges.
Thanks for the info.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
