Fuel in the oil????
Old Apr 20, 2008 | 11:35 AM
pickupman96's Avatar
Fuel in the oil????
So i just installed my new injectors and everything went real smooth. The truck runs fine my only problem is that I think that my oil level has raised. I cant smell any fuel in it. I dont know if it really has or my head playing tricks on me. If there was fuel in the oil wouldnt I be able to smell it or I put a few drops on a paper towel and I cant see any. What do you guys think
Old Apr 20, 2008 | 03:48 PM
Tate's Avatar
Pull the valve cover off and run the engine, look for fuel coming out of the injectors. You've got a leaky o-ring somewhere.
Old Apr 20, 2008 | 04:12 PM
I should smell fuel in the oil though right
Old Apr 20, 2008 | 05:25 PM
nickg's Avatar
Yep it would smell like diesel, or send in a sample for testing, if its diesel they will find it.. locally here oil sample kits are 18-22 each depending where you buy them (Amsoil/cummins/Finning)
Old Apr 20, 2008 | 07:49 PM
I just read something in another thread about delivery tube o-rings. Could these be the problem, I didnt pull them out when I did the injectors just pulled the lines off and pried the delivery tubes out 1/4 inch or so and droped int the injectors and turned them slightly until i could feel the tubes push into place
Old Apr 20, 2008 | 09:28 PM
ytodd's Avatar
Originally Posted by pickupman96
I just read something in another thread about delivery tube o-rings. Could these be the problem...
Look up a few threads
Old Apr 21, 2008 | 03:34 AM
bullboy85's Avatar
well make sure there is fuel in there first, i read somewhere u could put a drop of fuel on a paper towl and let it soke in and if theres a light ring around then dark oil spot, like a notesable ring, then u have diesel in your oil
Old Apr 21, 2008 | 08:56 AM
dzlfarmboy's Avatar
You probably have a crossover tube that is either torn or broken, they seem to get brittle with age. Get six new ones and try them their pretty cheap.
Old Apr 21, 2008 | 03:45 PM
Tate's Avatar
A leaky crossover shouldn't be letting fuel into the oil, since its the o-ring on the injector body that seals the fuel return passage in the head from the valvetrain. No?
ian515
Oct 16, 2007 07:02 PM
TxDiesel007
15
Jan 18, 2006 01:19 PM
