FP Gauge
FP Gauge
Hey,
So I have everything to run my permanent gauge set and am now wondering if I should run the snubber off the big line elbow, then a 3 ft braided hose to the sender, or can I just attach the sender to the end of the snubber at the vp inlet?
Thoughts/suggestions
Thanks, Kurt
Thanks, Kurt
I would suggest teeing off the line as far from the VP as you can get while staying on the outlet side of the fuel filter. If you have the stock fuel filter housing in place then you can get a tapped 90* elbow which mounts to the filter housing outlet and will give you a port to run fuel pressure from.
mtl0727
Oct 12, 2005 01:02 PM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
