First Box
First Box
O.K, I'm curious what all everyone reccomends for the first fueling box on a 24V.
EZ?
Comp?
Hot Comp?
Van Aikken?
BD?
I would give the MAD a try instead but I like the idea of the adjustable box and being able to disable it for emmmsion testing.
Welcome all sugestions.
EZ?
Comp?
Hot Comp?
Van Aikken?
BD?
I agree with mishkaya. Skip the EZ and go for the Comp. I am saving my pennies for it. I have gone from "I'm not ever gonna put a box on" to "ok, I'll just put the EZ on" to "Well, once I get used to the EZ, I will want more, so I'll get a Comp". Might as well get it the first time and not buy 2 boxes. (Also gonna start saving for a clutch, you might want to think about it also if you tap the wire)
This site is a bad influence
~Rob
~Rob
I don't think so, the regular Con-O will hold 400 h.p, I don't plan on going over that limit anyway.
Just a box for a little extra zing when towing really, maybe add some injectors for some street fun. Intake and exhaust as well.
Nothing too wild.
Nothing too wild.
I am in the same boat, should I get a edge comp or the mad ECM, so many choices, what to do. I have read all the posts on low,mid high range torque all that good stuff but still can not decide.
General rule of thumb: HO trucks respond to injectors better, ETC's respond to boxes better.
Personal experience: I got the Comp first since you'll need a boost fooler to get much gain from any mods (get the HX35 up to 32-35# boost with elbow and wastegate), added injectors and turbo at the same time later. I'll have to wait for a couple weeks about the MadECM , it's on order!!
And it never stops, I'll be looking for bigger injectors soon, fabbing up an external wastegate now, twins before next year...
The Comp box and a MAD ecm are two very different beasts. The Comp will generate more HP than the MAD if you hook up the pump wire. So comparing the two is not really accurate...... I would compare the MAD to something like an Edge EZ, both of these make almost identical peak HP.
The guys running the MAD are extremely happy and it appears that the truck has better bottom end with the MAD than an EZ (but i have not had the opportunity to try one personally).
Doug
Doug
04ctd
Oct 5, 2006 08:27 PM
1stTimeAround
Oct 10, 2004 04:02 PM
bellyscraper
Dec 20, 2003 01:52 PM
BulletMan
Oct 31, 2003 10:02 AM
