fire rings
Old Dec 9, 2004 | 09:28 PM
clc900's Avatar
fire rings
When doing fire rings, are both the head and the block grooved or can I just have the head done?
Thanks,
Chad
Old Dec 9, 2004 | 11:25 PM
K2Cummins's Avatar
I think that only the head is done.
Old Dec 10, 2004 | 12:31 AM
LanceD's Avatar
is fire ring the same as O ring?
Old Dec 10, 2004 | 01:45 AM
JBlock's Avatar
Similar But metal rings
Fire rings are metal,
Old Dec 10, 2004 | 02:30 AM
LanceD's Avatar
what kind of metal?
I was at a machine shop the other day and they said they could O-ring my block with stainless steel rings instead of copper which they said is better, for 150 bucks, however I would have to remove the block and bring it to them. haha yea right. can this be done to just the head?
Old Dec 10, 2004 | 03:13 AM
BigBlue's Avatar
I think most people usually just do the head. It's cheaper to replace one of those than a new block.
Old Dec 10, 2004 | 05:47 AM
banshee's Avatar
For the most permanent results the grooves should be cut into the block by a machine shop that has done it before. They have to be spot on to ensure the rings will seal properly. The coffee grinder tool is also available to those who don't want to remove their block, but its sealing record isn't as good. When done properly fire rings + studs are failure free.
John
Old Dec 10, 2004 | 09:51 AM
infidel's Avatar
It can be done to either the head or block. Never heard that it makes any difference unless someone screws up.
Old Dec 10, 2004 | 10:00 AM
clc900's Avatar
So it can be either one and doesnt have to be both. I just want to have my head done since I have it off and taking the block in would be a pain. If just the head can be done with good results then great!!
Old Dec 11, 2004 | 02:25 AM
joefarmer's Avatar
I've had great results with my orings, ARP studs and head work done by DonM @ www.f1diesel.com. I'd atleast check with him to see what he's got to offer. His after the sale service is simply stellar.
brandon.
Old Dec 11, 2004 | 10:08 PM
ratsun's Avatar
Re: Similar But metal rings
My Oringed gasser used SS rings
Old Dec 12, 2004 | 08:03 AM
Dieseldude4x4's Avatar
Scheid o-ringed my block while the engine was being puffed up a bit. And went to bigger head studs.
Old Dec 12, 2004 | 04:55 PM
jermey1980's Avatar
scheid and haisley can cut fire ring with the motor still in the truck they use copper because they a re crushed to make a good seal the deck and head both have to be in within .003 they will not cut them if they are over that
ahire
13
Oct 17, 2008 12:50 PM
BigErksG2
Sep 25, 2008 06:43 PM
12VRoush
Oct 15, 2007 08:00 PM
1320
Mar 8, 2005 08:56 PM
