finaly i dectied(i think)
Old Jan 24, 2007 | 06:30 PM
01smokin's Avatar
i think i decited 2 go with sb,dd 3600, ddp 200hp sticks, ps64 or 66 that is the the dicision i need help on. i am doing 5 inch exh to a singlt 5 inch stack and plan 2 do water meth and a shot of juice what do u think
Old Jan 24, 2007 | 07:24 PM
dieselfan's Avatar
i would do the 66 for sure.
Old Jan 24, 2007 | 07:26 PM
01smokin's Avatar
why do u say that
Old Jan 24, 2007 | 07:29 PM
Muddin_dude06's Avatar
Well I would do the 66 because it will leave more room to grow, as I think we all know once the "Bombing Bug" bites; it bites HARD... Also could you please add some correct grammar to your post, it will make it much easier to read and follow.
Old Jan 24, 2007 | 07:32 PM
mysterync's Avatar
I would stick a SO pump in , i wouldnt squeeze any juice on a daily driver! water meth and juice will make interesting combo
the 64 will be less laggy and work well with twins as well as the 62, the 66 will run cooler with alot more lag, considering youve considerd twins, i would go with a 64/12 for a good option for upgrade, The clutch sounds good ! A FE will hold, but how long i dont
Old Jan 24, 2007 | 07:39 PM
mysterync's Avatar
I agree , its nice to have a clear sentence, but i dont belive we should judge folks for there spelling! Personally , i have no problem with his spelling! but it is a free world and you are open to your opinion!
Old Jan 24, 2007 | 07:46 PM
dieselfan's Avatar
Originally Posted by 01smokin
why do u say that
first i didnt know you were considering twins. if i did i would go with a 64/12or14 possibly a 62/14.
second i said a 66 cause you got a manual transmission and you want big sticks= big air=66.
Old Jan 24, 2007 | 07:48 PM
BigBlue's Avatar
I'm running the combo in my sig and with the TST COMP on 9 I'm hitting 1500* at 90mph and by the end of the 1/4 I've only been in the red for a couple of seconds which ain't bad. I'm incredibly impressed by how well my 62/12 cools and spools. Far beyond my expectations.
Old Jan 24, 2007 | 07:52 PM
01smokin's Avatar
sry about that i will try to use good gramer. does the 66 spool good ,how many rpm and how much boost(head studs and o ringed)
Old Jan 24, 2007 | 07:56 PM
mysterync's Avatar
wasnt he looking at twins before?
Old Jan 24, 2007 | 07:58 PM
mysterync's Avatar
66 spools at about 1500 if i remember right..duh i have one ,45 lbs is very efficent up to 55 you should be fine!
Old Jan 24, 2007 | 08:04 PM
01smokin's Avatar
yes i was looking at twins
Old Jan 24, 2007 | 08:07 PM
01smokin's Avatar
keep the sugestions comming. i want lots of choices to chose from
Old Jan 24, 2007 | 08:18 PM
If Industtrial Injection makes their new "Silver 62" for the '94-'02 that could be a very good turbo to use as well.
Old Jan 24, 2007 | 09:05 PM
blackdiesel's Avatar
Registered
i would do the 64/14 for a single, or do the 62/14 if you were going to twins.
