FASS users with the stock filter canister
Old Dec 7, 2005 | 05:58 PM
greenworks's Avatar
do you fellas run without he stock filter or without, I was thining running without just to save the 20 bucks on the filter, really isn't doing anything anyways.I only want the canister there to heat the fuel in cold weather.
Old Dec 7, 2005 | 06:13 PM
Diesel-Dan's Avatar
Dump the Fuel filter Bowl.......Frees up TONS of room! Yeah...the heater is great....but do you really need it? I know its cold up there...but additives and winter fuel? Mines MIA....Makes Mad ECM Changes a SNAP!!!!! haha.....
Old Dec 7, 2005 | 06:44 PM
greenworks's Avatar
I f I lived where you are I would agree, but this week we have seen -30'c, I use additves but still would like to run the fuel heater canister, I am more or less wondering if there will be a problem running the unit with no filter, will it work as it supposed to?
Old Dec 7, 2005 | 06:49 PM
crobtex's Avatar
FASS with filters or FASS II?
Old Dec 7, 2005 | 07:08 PM
rebal's Avatar
put a new filter in it and forget it .if the fass has filters it will never get dirty again
Old Dec 7, 2005 | 08:45 PM
Diesel-Dan's Avatar
Lets start something here and now to ease confusion:
FASS = Fuel Air Seporations System
HPFP = High Pressure Fuel Pump AkA = FASS II; Baby FASS
SOOOOOOO FASS has filters....the HPFP has a "Rock Filter" (Prefilter)
The FASS Does not need the stock unit to filter. The HPFP Does. You can rig a heater if needed.....you may loose some pressure running it through the stock canister...but not enough to worry...unless you are pushing 800+ haha!
Dan
Old Dec 7, 2005 | 08:55 PM
Dr. Evil's Avatar
Cant you just use the stock filter housing without a filter?? IE, to just use the heater....??
Old Dec 7, 2005 | 09:02 PM
Diesel-Dan's Avatar
GREAT POINT! I think that would work great.....Or rig something with the stock heater...pull it out of the canister......
Old Dec 8, 2005 | 05:17 AM
claymx's Avatar
when i had mine installed by NADP they bypassed the filter housing and directly to the VP. would that pump not create alot of heat running full blast all the time? would you want to bypass the fuel heater in the summer wouldn't you so you don't over heat the VP? i was thinking about plumbing it into fuel heat/filter canister myself. i guess you could just unplugthe heater in summer,eh?
Clay
Old Dec 8, 2005 | 09:01 AM
greenworks's Avatar
isn't that how I started this thread, all I want to know is running without the filter in the canister going to affect the way it works, I guess no but has anybody tried it?
Old Dec 8, 2005 | 09:14 AM
6WHEELER's Avatar
I am running the fass system thourgh my stock canister with out the filter in it. For the heater and water in the fuel sensor, don't know if I really need them but got them. I cut the top outer ring off the old fuel filter and use it as a gasket between the housing and the top.
Old Dec 8, 2005 | 09:37 AM
Ben's Avatar
Ben
True that!! My forearm still is shows the scars from that swap.LOL
Old Dec 8, 2005 | 10:55 AM
airman's Avatar
Something to think about
I am using my original filter also.The fass pump is a rotory vane pump that means you have two metal service's rubbing against each other and you could have wear particals from your pump that without the filter could ruin the vp44.Too me its cheaper to buy the filter than too take the chance I've already broke most everthing else.Just my way of thinking.
Old Dec 8, 2005 | 03:12 PM
cditrani's Avatar
The FASS pump, at least in the generation I have, is a gerotor pump, not a vane pump (a big selling point for me). Not that it bears on your point about wear particles.
madhat
Mar 8, 2010 08:10 PM
dodge_24
Oct 1, 2009 05:33 PM
jcamron
Sep 10, 2009 10:54 PM
Moobesor
28
Jan 8, 2009 01:54 PM
rufushusky
Feb 24, 2008 12:57 PM
