Removing the stock fuel filter canister...
Just a crazy idea I was thinking of replacing the stock fuel filter drop in canister with a spin on fuel filter head...something like this:
DSCF0475.jpg?t=1203797070
I got my fass down by the tank so other then fabing up a bracket would I have any problems with adding this in place of my stock canister??
You'll lose the fuel heater, water in fuel sensor and, not a lot of room to spin that on or off. I made a bracket to mount an additional filter to the intake horn. 2 bolts and I can have it off/loose to change the filter. here's a link to the post with pics. Fleetguard does make a filter that has the WIF sensor in the bottom that you could plug the factory connector into, but it is only 10 micron. A lot of the aftermarket filters that drop into the factory canister are 7 micron or 10 mic from the factory. Seems kind of counter productive.
post # 8 of this link ( oh....I lost the BD pump and went to a Walbro too! )
https://www.dieseltruckresource.com/...&highlight=mic
Keep the stock filter and run the cat filter along with it. You get to keep all the features of the stock housing and can build a staged filtration system. You can run everything through the stock canister first then to the 2u filter. That way the stock filter can catch everything larger than 5, 7 or 10 micron depending on what filter you use and then let the 2u filter deal with everything smaller than that.
madhat
Mar 8, 2010 08:10 PM
dodge_24
Oct 1, 2009 05:33 PM
jcamron
Sep 10, 2009 10:54 PM
Moobesor
28
Jan 8, 2009 01:54 PM
greenworks
13
Dec 8, 2005 03:12 PM
