FASS question
Old Feb 21, 2007 | 01:15 PM
fade94's Avatar
FASS question
My kit came with 1 3/8" x 1/4" bolts to mount the flat bracket to the pump assembly. They are too long. 1" would have been fine. I had to use 3 washers to get them to sinch down so I could drive my truck. Will be picking up shorter bolts today. Anybody else run into this?
Old Feb 21, 2007 | 01:22 PM
White00's Avatar
It's been so long since I put mine on I don't remember if my bolts were too long. I would say if everthing is tight, then it would be fine to drive until you get some shorter ones.
Old Feb 21, 2007 | 05:46 PM
John_P's Avatar
fade94:
At your request I deleted that duplicate post for you!
John_P
Old Feb 21, 2007 | 06:05 PM
Diesel-Dan's Avatar
About 4 months ago, we had an error in our mounting package assembly book. Wrong bolt was listed. After about 4 dealers calling me with this issue, i found the prob and it was changed. I’m guessing your unit was made mid to early late last year before we implemented this change. I can get you bolts if you wish if you have your dealer call me with your contact info and SN. Sorry for the inconvenience.
Old Feb 21, 2007 | 09:04 PM
fade94's Avatar
Dan, does that mean I don't have the new pump design? My system was drop shipped from DPP.
Old Feb 22, 2007 | 08:32 AM
Diesel-Dan's Avatar
I need to check the book again now that you say this.......but i cant tell nothing without your SN.
Old Feb 22, 2007 | 10:12 AM
fade94's Avatar
I assume it is on the plate on the side of the unit. I will get the number when I get a chance. Midwest assured me I would be getting the newest pump design, but this isn't the first time they have not provided correct info if I don't have it.
BCarmicle
13
Nov 7, 2005 04:20 PM
Buckshotmckee
May 23, 2005 12:08 AM
2wheelsup
May 17, 2005 10:45 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
