FASS pump ?'s
Old Feb 23, 2010 | 11:44 AM
BAGGERMAN's Avatar
FASS pump ?'s
I've got a 95gal.pump only.The problem i am having is at idle it has 15 psi, when i hammer it i can pull it all the way down to 5 psi.I have an external gauge that i can plumb into the injection pump with same results.it used to be that i had a hard time pulling it down to 9 psi when i nailed it.any ideas.
Old Feb 23, 2010 | 12:24 PM
RowJ's Avatar
Originally Posted by BAGGERMAN
.....it used to be that i had a hard time pulling it down to 9 psi when i nailed it.any ideas.
was this when FASS was new .... or before HPFP (FASS pump only)?
If the 9 psi was also HPFP, could be as simple as time to change fuel filter.
I assume you eliminated the lift pump when you installed HPFP?
RJ
Old Feb 23, 2010 | 06:13 PM
DIESELWRKS's Avatar
yes how old is your fass. does it have a polishe alumn block on it holding it to the frame. also how are you getting your fuel from your tank. do you have a draw straw. and like mentioned before. the filters. before I was upgraded to the fass 150. I had the 95 old style but I had 14psi on wot. and around 18 idle. it started to weep and they replaced it free and with a 150 model and now have 21psi at idle and never below 15psi.
Old Feb 23, 2010 | 07:01 PM
BAGGERMAN's Avatar
I changed the filter same prob.i have a draw straw it's been sitting on my work bench for over a year which probably isn't doing a lot of good.the pump is the newer one 3 yrs old or so.i had the alum.block off yesterday and streched the spring a little but didn't do much, i guess i'll have to drop the tank and do the draw straw.
ollie32
Jun 3, 2007 09:29 PM
Timberman
Dec 15, 2006 09:12 PM
BCarmicle
13
Nov 7, 2005 04:20 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
