Fass pump
Old Apr 2, 2007 | 10:22 PM
Rich26's Avatar
Fass pump
My truck originally had the stock lift pump mounted to the block but when i got it it had been converted to an intank pump. I have an edge comp drag box and 5 inch straight pipe I wanna put a fass 95gph on because I plan on doing and stage 5 injector nozzles. How do I go about installing the fass? Do I need to unhook the intank pump and still use the fuel lines that run into the tank?
Old Apr 2, 2007 | 10:38 PM
smokindog's Avatar
Not 100% on how to do it with the retrofit pump in there, but it can't be that difficult. I haven't seen an in tank pump yet so I could be way wrong, but give Diesel Dan a shout and he will walk you through it all.
I can tell you that installing a FASS on a truck with the old lift pump is an absolute piece of cake though.
Old Apr 2, 2007 | 11:11 PM
deruwe2002's Avatar
I just put one on the other week. Although I didn't have the in-take pump, it was quick and easy. The only extra step with the in-tank pump is that you'll need to add a draw straw, which will require dropping the tank. I'm sure somebody will have some knowledge of how good or bad that was to install.
Old Apr 3, 2007 | 08:07 AM
crobtex's Avatar
I don't think the FASS will work well with the in tank pump. I'm sure Diesel-Dan will be on here with a good answer.
Old Apr 3, 2007 | 10:27 AM
ohiostate24's Avatar
I had the intank pump before I put my Fass pump in, and I was advised it would be better to get another factory "sump" and put it back in the tank for the FASS. The FASS wont work with the intank pump, you can use a draw straw, but of course there are downfalls to that also.
Old Apr 3, 2007 | 01:41 PM
Diesel-Dan's Avatar
Looks like you got some good suggestions here.
The FASS/HPFP will not draw through the intank pump. You will need to install a stock module, or install a Suction Tube Kit. (STK-1001)
Vulcan Draw Straws only works with the stock modules IIRC. Will not work with the intank pump setups.
Old Apr 3, 2007 | 02:19 PM
b4wheeler's Avatar
The Draw Straw just replaces the factory in-tank pump. The module remains to monitor the fuel level. I wish I had purchased a used non-in-tank module and just replaced it. Would have been a cleaner install. You will still have to drop the tank.
There is a non-in-tank pump module for sale in the classifieds right now....
Old Apr 3, 2007 | 10:05 PM
Tate's Avatar
They have the Draw Straw II that is meant for the intank pump modules.
Old Apr 4, 2007 | 12:39 PM
Diesel-Dan's Avatar
Yeah...the DSII is just like our STK-1001........Eric makes part of it for us actually.....
Old Apr 4, 2007 | 05:29 PM
Rich26's Avatar
So if i purchase the vulcan draw straw II couldnt i just unhook the power wire to the old pump or just take the old pump out of the sending unit and run the draw straw in?
Old Apr 4, 2007 | 05:49 PM
Diesel-Dan's Avatar
No....the DSII or our STK-1001 are remote mount. Meaning that you drill a hole in the top of your tank to install the pick up. You just leave the pump in the tank and dont mess with it. It will be unpluged when you plug in the FASS harness up at the engine.
Old Apr 4, 2007 | 06:21 PM
Rich26's Avatar
so just the power wire to my pump would plug into the fass harness and my fuel gauge will still work?
Old Apr 4, 2007 | 06:45 PM
crobtex's Avatar
Yes.....
Old Apr 4, 2007 | 07:32 PM
Rich26's Avatar
ok thanks for all the great info i know that i ask a lot of questions but i just cant afford to get everything apart and than not have the right stuff to finish so thanks again
ollie32
Jun 3, 2007 09:29 PM
Timberman
Dec 15, 2006 09:12 PM
BCarmicle
13
Nov 7, 2005 04:20 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
