Fass 95 Or 150
Old Aug 1, 2006 | 02:10 AM
jyama69's Avatar
Fass 95 Or 150
I am starting to build my truck, (2001 2500 4x4 auto, quad cab) I hope to produce as least 400hp or a little more. I heard to much pressure is not good. But in the "far" future I want to run twins with bigger injectors. Should I run the 95 or just get the 150. Comments welcome. Thank you.
Old Aug 1, 2006 | 08:09 AM
Diesel-Dan's Avatar
We have not found a VP-44 that could run away from the 95 GPH FASS/HPFP. I have seen the 95 GPH on 600+ HP trucks with only 1.5 psi drop at WOT. I feel that the 95 GPH would be perfect for your truck.
Old Aug 1, 2006 | 10:44 AM
HP Upgrades's Avatar
I agree with Diesel Dan, have sold mostly 95 systems and have had claims of big numbers with no problems.
Old Aug 1, 2006 | 11:23 PM
jyama69's Avatar
95 it is thanks.
Old Aug 2, 2006 | 10:54 AM
jriggs_18's Avatar
I am also looking into the Fass, and wondered, does the 150 make more pressure? I dont believe it costs anymore for the 150, so are there any downfalls to it vs. the 95?
Old Aug 2, 2006 | 11:12 AM
Diesel-Dan's Avatar
The 150 GPH makes about 1 lb more pressure on average. BUT the 95 GPH has a higher pressure ceiling...meaning you can run the 95 GPH up to 80 PSI and the 150 GPH to 25 PSI before motor amperage becomes an issue.
rjm022
Oct 20, 2014 02:29 PM
CrashCade
Dec 3, 2008 07:58 AM
dodgediesel
26
Nov 2, 2008 12:20 PM
curts99
Feb 14, 2008 12:09 AM
Ramtuff06
Aug 21, 2007 06:21 AM
