Fass 2
Just got the fass 2 installed this morning. It's a nice set-up, kit comes with pretty much everything you need, Jason did buy an elbow fitting to replace the straight on the pump fitting for the hose going back into the tank due to the limited space on the swb, so the line would not rub against the sheet metal.
My gauge only reads up to 16 psi, (got the 150 gph one}so it reads max except on take off with comp on 5x5 got it down to 14 for a split second then back up it went.
Hope this will last me, tired of the o&ms going for only a year or so.
Originally posted by Wilson
What is the difference between fass 1 and fass 2?
cul,
Casey
BCarmicle
13
Nov 7, 2005 04:20 PM
Buckshotmckee
May 23, 2005 12:08 AM
Flatty
Apr 25, 2005 12:49 PM
