F1 VS Jammers
Old Feb 3, 2007 | 02:05 AM
dodge2001's Avatar
Question F1 VS Jammers
i plan on getting a Super Phat Shaft 62 or a Phat Shaft 64 in the next yr or so and i am going to go with a set of 100hp injectors. i've heard good things about both, but i heard that the jammers make the egt's higher.
not real sure how but like i said "i heard". thanks for the help
Old Feb 3, 2007 | 08:08 AM
dieselfan's Avatar
jammers are good for the price, if you go with jammers get at least 125's or 150's. they are a little over rated on hp JMO.
If you can afford them and want the best get the Mach's.
Old Feb 3, 2007 | 09:22 AM
S.Dodge's Avatar
How would the 125's or 150's be on a stock turbo with a comp , I know they would get hot but would it be managable cruising and I don't tow alot barley at all 4K-5K couple times a year., I could just turn the comp down or off or would I need a new turbo?
Old Feb 3, 2007 | 09:38 AM
blackdiesel's Avatar
Registered
back when i was just startin out bombing my rig, i had jammer 4's in it with a comp on the stock hx35. And yes, it does get way to hot.
i pulled 25K+ with just the injectors and the comp on 1x1 for timing, and it got warm, but not unmanagable.
so yes, you could do it but a ps62/12 would be better suited for the job
Old Feb 3, 2007 | 09:50 AM
AlpineRAM's Avatar
Don't go for too small a turbo for the job....
Getting to see this is much work and will not really make you happy.
AlpineRAM
Old Feb 3, 2007 | 01:46 PM
zulusafari's Avatar
Ouch!! That looks both expensive and sad!
Old Feb 3, 2007 | 01:56 PM
John DiMartino's Avatar
Dont skimp on nozzles,get the best. The Mach injectors from Don M.Fuel is everything on a diesel,how its delvered,when and the pattern,and angle.No one has better injectors than Don M.
Old Feb 3, 2007 | 02:55 PM
dodgediesel's Avatar
Geez, I have a similar looking piston on my work bench... Sure wish I had my pyro pre turbo when I melted my piston skirt like yours...
Old Feb 5, 2007 | 08:14 AM
2broke2smoke's Avatar
my truck did 200 stock and 330 with jammer 4's ...
everything else the same
Old Feb 5, 2007 | 08:29 AM
dieselfan's Avatar
thanks for posting that. i thought they produced alittle less than claimed, guess not.
Old Feb 5, 2007 | 10:24 AM
TheBigNasty's Avatar
Jammers Vs F1.....is that really a comparison?
one54ton
23
Nov 24, 2008 03:47 PM
storx
Sep 4, 2005 04:07 AM
Mixer Man
Aug 4, 2005 08:00 PM
pmtg
14
Jun 12, 2004 06:19 PM
FiverBob
41
Dec 16, 2003 06:14 PM
