F1 injectors?
Old Aug 28, 2008 | 10:37 PM
  #46
dieselfan's Avatar
Originally Posted by Flatbed24v
if I want to go over 500 hp with the Mach 4's (I hope to reach 700-800 hp) what problems will I run in to with them?
i would focus on 500-600hp then worry about 700-800 later on. it isnt that easy with vp trucks. doable but lots of $$$$
Old Aug 29, 2008 | 08:07 AM
  #47
Mike Holmen's Avatar
The Guru
A set of mach's 4 in a VP truck that working right/properely will be very close to high 500's or low 600's. Twins turbos would be the ticket to get very close to 600's on #2. Put in some squeeze and meth, you should be in the 800+ area, depending on how much methanol and NOS you're dumping. Most big HP dyno trucks use NOS to get to 700+ ponies, not too many can do that just on fuel regardless of injection pump type. If you want a dyno day special set of sticks, Don builds a mach 8's just for NOS, just make sure you have a good injection pump.
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
