to ez....or not?
Old Mar 25, 2004 | 08:55 PM
firepiper's Avatar
Question to ez....or not?
Hello all. My '99 CTD needs some zip, for towing my 5th wheel. I have the air in and out covered. I'm thinking about an ez edge....does this have a boost fooler in it? I notice that even with the min mods I have I push up around 25-27 psi. I'm still under warranty, so don't want to set any codes!! Thanks, Mark
Old Mar 25, 2004 | 10:20 PM
farmer dave's Avatar
I am prett sure that they come with a boost elbow
Old Mar 25, 2004 | 10:36 PM
billg's Avatar
I have the EZ and I tow an 8080lb 5th wheel. It is great for towing. And yes it has a boost fooler built in and a boost elbow comes in the box. At least that’s the way mine came. In fact I just got back from a trip up to Uxbridge MA with the truck. Was able to pull the hills on I395 doing about 68 mph with EGTs no greater than 1000 degf. I couldn't do that before the EZ.
Old Mar 25, 2004 | 10:50 PM
Sixpack's Avatar
I really like my setup for towing our 5r. And yes, built in boost fooler and mine also came with the boost elbow. My boost maxes out at 32 psi. What is with your nickname "firepiper" Just curious Phil
Old Mar 26, 2004 | 04:50 AM
firepiper's Avatar
Thanks for the info. I'm gonna get me one! And as for the logon, I am a firefighter who plays the pipes. thanks
Old Mar 26, 2004 | 10:35 AM
rjordan's Avatar
DO IT!!! the EZ does have a boost fooler for the computer, and does come with an elbow for the turbo. You wont regret getting one. i have one and my max boost is at 33 PSI.
Old Mar 26, 2004 | 01:36 PM
DPG's Avatar
DPG
firepiper,
I agree with everyone. I also have a '99, and the EZ made a big difference. Really brought some life to the CTD. I've been running mine for over a year, and all is well, no codes. Just a hint: when you plug in the EZ to the MAP sensor, make sure that the engine is cool, and lay right on the valve cover from the front of the truck. Being slightly altitude-challenged (5'9") that was the only way I could reach the MAP sensor plug. After I figured that out, it took me about 5 minutes to install.
Old Mar 27, 2004 | 04:23 PM
ramcummins's Avatar
Awesome choice for a mild upgrade. any warranty work just unplug it.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
04ctd
Mar 8, 2006 11:22 AM
Scotty
Sep 11, 2005 12:37 AM
NHDiesel
Sep 2, 2005 11:23 AM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
