EZ mod?
Old Oct 2, 2008 | 05:57 PM
lefty10's Avatar
EZ mod?
Ive read on a few posts people talking about a "mod" on their EZ wat does that mean? Thanks
Old Oct 2, 2008 | 08:30 PM
scottsjeeprolet's Avatar
You don't need the EZ and a boost fooler. The EZ does the fooling. You can unplug the MAP from the block and it will give you some more bottom end power. Leave it plugged into the EZ harness just unplug it from the block.
Old Oct 2, 2008 | 10:45 PM
rage_blue's Avatar
put a resistor across the outer two wires on the map sensor, i use a 3 ohm it creates more smoke, or just jumper the wires. tricks the ez into putting out more feul.
Old Oct 3, 2008 | 12:32 AM
lefty10's Avatar
i'm sorry what do you mean a resistor?
Old Oct 3, 2008 | 02:32 AM
2500CTD's Avatar
Pick ur flavor. Radio shack has them. I dunno how much of a power rating u need for this mod as I dont have an EZ.
Old Oct 3, 2008 | 05:53 AM
Ya Um don't do the resistor thing. I've never heard of doing it for one.
KISS (keep it simple stupid) Just unplug the MAP from the block and drive it for a few days. If it's not enough then save up for a Comp or Smarty.
Get rid of the boost fooler, did you install the boost elbow on the Turbo?
Old Oct 4, 2008 | 08:57 PM
mxjim4x4's Avatar
does it throe CEL light
Old Oct 4, 2008 | 10:14 PM
lefty10's Avatar
no i have the wastegate plugged
Old Oct 5, 2008 | 10:21 AM
Unplugging the MAP from the block only works with and EDGE EZ or Comp.
You leave the edge harness plugged into the factory harness just unplug the MAP @ the block.
No it won't throw a CEL if you have an Edge, but i've heard unplugging the MAP doesn't work with the Juice.
Old Oct 5, 2008 | 12:38 PM
mxjim4x4's Avatar
I have a smarty also can i leave that hooked up when the map is unpluged
Old Oct 5, 2008 | 02:46 PM
ONLY WORKS WITH THE EDGE COMP OR EZ!!!!!!
If your stacking your Smarty with the Edge no need as the Smarty gives plenty of low end power.
I actually plugged my MAP back in when i stacked the Smarty / Comp.
Old Oct 5, 2008 | 05:17 PM
dodge2001's Avatar
if you do a EZ/TST PM3 stack you won't need to unplug anything...lol...i can black out 2 lanes if i so desire....
Kenworth
Jul 15, 2008 04:18 PM
jmccart
Dec 19, 2007 12:49 AM
jamesbfishin
Jul 7, 2007 08:25 PM
wap
14
Apr 23, 2007 06:46 PM
RAMV
Jul 14, 2004 12:08 PM
