ez edge 1000
ez edge 1000
im looking to up grade to a ts performance chip and i recently tried to unplug my ez edge and have no clue what i put in place of the old plugin connections from the edge?? like at the map sensor and the wirein harness at the pump... i didn install it so i have no clue how to take it out when i get the new chip in. any help would be greatly appreciated thank you..
If it's just and Edge EZ I think they are only hooked up through MAP and Data Link I assume? With the Map Sensor just plug the OEM connection back into the sensor in the intake manifold. As far as the Data Link goes, there is no where for that plug to make a connection. You will want to seal up the plug so that moisture doesn't get in there. As far as I know that is all there is to the EZ, but correct me if I'm wrong.
Dinner's information is correct. Here are the instructions from Edge's website. http://www.edgeproducts.com/product_...manual-153.pdf
Jack3789
Aug 9, 2003 10:25 PM
