EZ COMP
Old Feb 8, 2003 | 08:46 PM
geer's Avatar
EZ COMP
I would like some input on this add on. Can I put this on my truck with out any other mods? The old ball and chain just doesn't see things the way I do. So I only have $700 to spend. Thanks,<br> Scooter ??? ???
Old Feb 8, 2003 | 08:50 PM
PourinDiesel's Avatar
Re:EZ COMP
Yes, but I would recommend not hooking up the pump wire and your Comp will act as an EZ.<br>With just the Comp no pump wire you will have 65 extra hp and will be able to get away without gauges.<br><br>But I do suggest buying gauges, and probably a BHAF air filter.<br>Your stock clutch should be ok with just the 65 extra hp.<br><br>--Justin
Old Feb 8, 2003 | 08:53 PM
geer's Avatar
Re:EZ COMP
Thanks. This is a great site. I am just starting to BOMB and very excited about it. ;D ;D ;D ;D
Old Feb 9, 2003 | 01:36 PM
Roger rodbolt's Avatar
Re:EZ COMP
Scooter,<br>There is a lot of good information regarding bombing but please do your research carefully. Your 2002 high output responds a little differently to electronic enhancements and injectors then do the standard output engine. In fact, hooking up the &quot;EZ&quot; side of a Edge Comp will net you less horsepower then it will on a standard engine. What I'm saying is that with an HO the EZ will not make the 65 horsepower increase as advertised. I've installed two major fueling boxes on 2002's and a '98.5 in the past week and there is a diffence in engine hp and response between the HO's and standard ETC's though all were happy. There are folks that are happy with only electronic &quot;bombs&quot; on an HO but if you have limited funds and wish to stay with a stock clutch I recommend a good set of aftermarket injectors. The HO's<br>respond better then advertised to enhanced injectors and for a given power range the torque is moved higher within the rpm range. This allows more power to be had without slipping your stock clutch. HTH's, Larry
Old Feb 9, 2003 | 06:47 PM
geer's Avatar
Re:EZ COMP
Thanks for the info. What size injectors would you recommend? Also what type of HP increase would I see?<br> Scooter
MoreSmoke
Jan 7, 2004 09:40 PM
James Lucas
14
Aug 29, 2003 11:24 AM
hellotbone
Jul 12, 2003 12:58 AM
hellotbone
18
May 16, 2003 04:40 PM
danlit
Feb 13, 2003 10:53 AM
