Engine Temp with Fueling Boxes
Old Nov 2, 2003 | 09:18 AM
Gene007's Avatar
I had a BullyDog box (VanAAken Performance Tech). With this box (which plugs into the Fuel pump control module) I never really noticed much change in engine temps with moderate smoke. I have now installed a Power Edge Comp (wire not punched). With just the Edge I see a little more smoke and gain in power but the engine temp fluctuates a little more, My Pyro meter hasn't changed much in movement (Post Turbo). I finally got the nerve to stack the two boxes. With this I have lot more smoke, seems to have gained a little power but My engine temp moves more above normal and then cools down ok when taking it easy. (Not as much change in the Pyro) I believe the increase in fueling would move the Pyro but I'm thinking the timing change could be effecting my engine temps more than I would like. Do ya'll see much change in engine temps with your boxes, especially stacked? Also with the comp wire hooked up would I see more engine temps along with Exhaust temps?
Thanks,
Gene007
WarWagon
Old Nov 2, 2003 | 12:12 PM
StakeMan's Avatar
Re:Engine Temp with Fueling Boxes
Stacking a VA box and an Edge Comp box is a bad idea. You are advancing the timing a lot which raises cylinder pressures and could cause damage.
Old Nov 2, 2003 | 05:01 PM
HOHN's Avatar
The super-advanced timing on your truck is hurting efficiency a great deal. You can also grenade your truck. I recommend undoing this stack ASAP.
HOHN
t-boe
Jan 4, 2007 08:35 AM
Pike
17
Aug 5, 2004 12:18 AM
gsdog1
Jan 6, 2004 04:27 PM
John_P
24
Jul 13, 2003 08:59 AM
AKDSLDOG
Jun 1, 2003 04:33 PM
