engine shudder - Comp problem?
Old Nov 24, 2006 | 04:52 PM
Jasper's Avatar
Ok, just recently (in the last 3 weeks), my truck has started to shudder. It becomes WAY more noticeable the higher level i have my Comp set at, and it is barely noticeable with the Comp turned off. First thought was the tranny, but i have a basically new DTT trans and TC (maybe 8k miles on it). When i unplug the comp i cant feel the shudder anymore.
The heavier i get into the skinny pedal, the higher in rpm the shudder occurs. But it always happens around the 1-2 shift, sometimes before it and sometimes right after it.
So is the comp just goin haywire and i need to get it reprogrammed, or is it something else like my vp?
Old Nov 24, 2006 | 07:21 PM
lovinCTD59's Avatar
I guess I cant say for sure but Im guessing its the VP.. With advanced timing and fueling rates with the comp on. The VP is working harder.. maybe im wrong and its something cheaper... Good luck.
Old Nov 24, 2006 | 09:07 PM
Jasper's Avatar
Anyone else have a problem like this? It feels a little like it could be a defueling shudder, but im not sure.
Old Nov 25, 2006 | 09:07 AM
RowJ's Avatar
Should not be defueling with the Edge Comp?
I have never had anything like that... especially at the 1-2 shift. Mine shifts so soon after I start moving (with 3.55)... yours must be almost instantaneous w/ 4.10's ?
Does it happen with moderate to heavy acceleration or when carrying a load? I'm guessing it doesn't??
RJ
Old Nov 28, 2006 | 08:32 PM
Jasper's Avatar
it gets worse under heavier acceleration, i havent tried pulling anything since this started happening.
isnt it the comp drag that doesnt de-fuel?
Old Nov 29, 2006 | 07:47 AM
RowJ's Avatar
There are two kinds of defueling... but I would not call either a shudder.
I use to get the 'high torque/no speed' defueling before I got the Smarty... but only when I built boost while braking ... for drag racing. You should not be experiencing that??
The other defueling is at high rpm - 2700+. Your comp will not eliminate that either (yes, only the drag comp does)... but your not seeing that kind of rpm with your problem, are you?
RJ
schv
18
Jan 30, 2009 06:39 AM
Rafter B
Apr 13, 2008 09:40 AM
inline6power
26
Jan 24, 2007 12:12 PM
dodgediesel
15
Dec 17, 2006 12:13 PM
Spurs
Jul 28, 2005 01:23 PM
