EGT issues
Old Nov 17, 2009 | 05:52 PM
levibeardslee's Avatar
EGT issues
Just wondering if any of you share heat issues like mine? I have my pyro in the exhaust manifold and im not sure if i should put it in the down pipe? Any sugestions?
Old Nov 17, 2009 | 07:37 PM
busa's Avatar
Mounted in the exhaust manifold is more accurate. What are your temps?
Old Nov 17, 2009 | 07:42 PM
RR20012500's Avatar
your Edge Juiced is tapped.... I have been reading aobut this. what does that mean?? sorry, I am a new diesel owner. thanks for your help
Old Nov 17, 2009 | 08:37 PM
DIESELWRKS's Avatar
some people will do reading post or pre turbo. most do pre turbo to know what heat is coming right out of the manifold. aftermarket manifolds usually have a pre made bung. other wise I did dead center on mine. wire tapping in easy terms is going into the vp (injection pump) and your performance box is controlling your injection pump. based on fuel rpm boost etc. pending what box. some boxes dont tap and they max at around 65ish I think HP and tapped boxes pending other mods with the truck will be from 65ish to up to 120ish. hope this helps alittle more. all depends on the box.
Old Nov 17, 2009 | 10:00 PM
RR20012500's Avatar
Hey thanks alot. It helped. Mine is the Comp Box. i believe it is tapped via the MAP Sensor? It says it adds 120HP. Not sure how true those numbers are. it sure feels like it on the high settings
Old Nov 21, 2009 | 03:20 PM
6speedcowboy's Avatar
the Edge comp ties into the map sensor, can bus, and pump wire. it taps the pump wire via scotch lock or the better way is with a stealth cover. look for a single wire running up the the pump.
Old Nov 21, 2009 | 05:02 PM
Dinner's Avatar
levibeardslee, what temps are you running cruising, WOT, etc? Also, what mods do you have on the truck?
mainer
Mar 22, 2007 10:27 AM
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
89dieselkong
Sep 27, 2006 05:44 PM
