Edge turbo timer makes doors unlock
On my Juice with Attitude I have been taking advantage of the built in turbo timer but when I get back to my truck the doors are unlocked when I left it locked. I sat and waited to see what is going on and everytime the truck shuts off the doors automatically unlock. Is their any way to make it so the doors don't automatically unlock when the engine shuts off? Thanks, Eric
Mine does it also. When your not using the timer and you shut the truck off dont the doors unlock. Mine does. I start the truck the doors lock. I shut the truck off they unlock. I would think its a normal feature of the truck. I imagine theres a way to turn that feature off, but I dont know how.
Since we are on the topic, how do you bypass the timer when you don't want it? I thought that if you set the e-brake it was not supposed to count down but the setting the e-brake on mine has no effect.
There is a way to turn off the "auto locks" when the motor is running. I read it somewhere - but that feature was already turned off in my truck so I didn't try to enable it becasue it annoys me to have teh doors automaticly lock after I start the motor. So thats probably whats causing it.
I've tried using the switch on the door and using the remote and either way it unlocks the doors. I swear I've read how to unable this feature somewhere, I just can't seem to find it. Somebody has to know. Thanks, Eric
Found this with a search on here.
1. close all doors
2. place key in ign and cycle key off to on 4 times. Don't start engine.
3. press driver side power door lock switch to lock the doors within 30 seconds
4. you'll hear a single chime. Auto door lock is deactivated.
5. to enable, follow above steps.
7. To reactivate, repeat the above steps.
1. close all doors
IntakeRacing
Oct 26, 2011 01:00 AM
goat1966
Feb 3, 2009 12:12 PM
GrumpyTX
Aug 23, 2007 08:42 AM
