Edge EZ or?
Old Feb 28, 2006 | 03:26 PM
cjthor's Avatar
Edge EZ or?
The wife has said that I could spend some money on the truck. I was looking at the Edge EZ. My truck is 01 H.O. with a 6spd. I am more intrested in possible increasing the milage and not so intrested in more power. The EZ for my modle year only has one setting, 65 HP and X amount of tourqe increase. Will I see any increase in mpg's or am I better purchasing something else. A buddy of mine just stuck the EZ on his 06 Mega cab and did show some increase at level two and deffenetly showed about a 3 mpg increase on setting 1. I think the boxes after 03 have three settings. Setting number 2 on the new EZ is the same as the setting for the EZ available for my truck. I am looking for the least amount of hassel in the long run. Yes I will be getting gauages for the truck if I get a box installed. Only other plans I have are to switch everything to synthetics.
Any opinions?
SuperChips?
Quadzilla?
Thanks,
Old Feb 28, 2006 | 05:51 PM
displacedtexan's Avatar
I would go with a Smarty if you want to spend that much money.
And I would nix the Superchips/Hypertech unless you find a smokin deal on a used one.
Only other advice from me would be to also look at the Van Aaken boxes, similar to the EZ but about $100 less, and have only heard good things about them.
Old Feb 28, 2006 | 06:27 PM
graphitecumnz's Avatar
fyi, this thread will probably get moved to Performance and Accessories where it belongs.
but, I'd spend the money and get the Smarty... actually, I already did. My EZ is collecting dust now. I can't say that I saw an increase in mileage when I was running just the EZ but I could get 20 mpg(all highway). I couldn't tell you what my mileage is now because I've been running DD3's for a year and they are a little smokey.
click here for Smarty info
http://www.madselectronics.com/Smarty03.html
Old Feb 28, 2006 | 06:28 PM
Chevyboy51's Avatar
I like the Van Akan alot better than the ez
Old Feb 28, 2006 | 10:11 PM
MadDog01's Avatar
I've used the Ez and am currently using a Va smartbox 5 on my 01.5 ho with six seed. The Ez has three settings, they are behind the back cover of the module. When I towed I used the lowest setting. It made a huge difference over stock. It was fun on the high setting! The EZ had too much timing for my liking, I tow about 9,000lbs. My freind let me use his Va and I noticed less engine noise and smoother throttle response. As for me I already spent the money on the VA and am going to install Mach 1.6's later. For about $150.00 more than an Edge you can get a Smarty which, I believe has ten settings!! Everything from fuel saver to towing to let's have some fun!! Once you get mod bug it's a hard thing to stop. So research, research, research, so you can buy right the first time ---- it will save you money in the long run.
Gary
jwhip
28
May 29, 2005 11:32 AM
rockjeep73
Mar 25, 2005 03:34 AM
Hoss
13
Jun 18, 2004 06:14 PM
powerwagon440
Jan 20, 2003 08:50 PM
