Edge ez = mileage improvement?
Old Dec 17, 2002 | 08:59 PM
Duelin's Avatar
Well, does anyone know?<br><br>With the ez is there a mileage improvement ?<br>Loaded , or towing I suspect so, as the power gets you up to cruise speed quicker. <br><br>However empty may be another story. Has any one ever tried to check this out ? [undecided]<br><br>Gary <br>
Old Dec 17, 2002 | 09:05 PM
Scotty's Avatar
Top's Younger Twin
Re:Edge ez = mileage improvement?
1-2 mpg after the foot stops testing the power. <br><br>I think the timing advance does that.
Old Dec 18, 2002 | 11:47 AM
Belvedere65's Avatar
<br> I have also seen an improvement in fuel mileage with the EZ.
Old Dec 18, 2002 | 02:54 PM
Mathew's Avatar
I had a Diesel Dynamics true torque module (re-badged EZ) in my 01 H0. 20,000 miles without, 12,000 with before I traded for 03. I kept track of all fills and miles. I don't drive hard - only used the extra power once in a great while while getting up to speed. <br><br>Overall (total miles/total fuel) average without TTPM vs with TTPM was within .1 mpg (which was 19.?). <br><br>I never tow and drive primarily freeway/highway. INDICATED mileage on the computer read about 1mpg high after install, just about dead on before EZ.<br><br>Mathew
Old Dec 18, 2002 | 03:14 PM
doug's Avatar
I also noticed no mpg improvement when running empty, using the pencil, paper, and calculator method. In my case, my overhead computer is off (reads low) so the EZ fakes it out so that it is actually more accurate now! <br><br>Just as a reminder, the overhead trip computer gets its information from the ECM. The injection pump gets its instructions from the EZ box -- which means that the injection pump is getting more fuel than the overhead computer thinks it is.
Old Dec 18, 2002 | 05:08 PM
jec3's Avatar
Slightly off subject but, after I installed my 275's my actual mileage dropped .5 mpg with same driving habits. Before the 275's my computer was within .5 mpg vs. actual. After the 275's my computer is reading almost 2.5 mpg over. &quot;See honey, how the gas mileage improved with those new injectors&quot;.<br><br>An EZ will be my next purchase. Would love to get that .5 mpg back but the big question will my computer be off 4 + mpg with the EZ and the 275's? If so, my computer will be showing over 21 mpg city/highway! Anyone know how to hack the computer so I can get a Scotty II and 4 inch exhaust? Adding those would add at least 5 mpg more right ;D
Old Dec 18, 2002 | 05:15 PM
doug's Avatar
yea I think you can count on your overhead computer being even more innacurate with the EZ. But you might get that .5mpg back. The EZ changed by overhead accuracy by about 1 mpg. <br><br>just realize that the overhead computer gets its instructions from the ECM. normally, the ECM fires the injection pump but in this case the EZ re-maps the fueling instruction with one of its own. ergo, the pump delivers fuel for a longer period of time than the overhead computer thinks. When you add injectors, the injectors themselves cause the fuel delivery rate to increase. both affect the overhead.
Old Dec 18, 2002 | 11:06 PM
BigBlue's Avatar
Ive noticed a slight increase, maybe .5-1.5 in the city with my Comp in EZ mode.
Old Dec 18, 2002 | 11:14 PM
Marine's Avatar
Veteran: Marine Corp
I have not noticed any mileage improvement with my EZ in city driving. Highway-yes. The overhead console reads 1.5 mpg better than I am actually getting.<br><br>Mike
Derek Timm
May 13, 2011 01:37 PM
chuck41
Jul 21, 2010 05:51 AM
dlfrye
Apr 27, 2010 02:01 PM
hopak
Jul 13, 2006 06:41 AM
Andrew Martin
Oct 15, 2005 06:03 PM
