edge comp problem or pcm problem ?
Old Nov 17, 2006 | 07:23 PM
curts99's Avatar
99 24 v keeps giving me p0237 code for map sensor my modis scaner at work suggest pcm being the coulprit but that applies to a non programed truck i have replaced the map sensor and hasnt taken care of the problem no wiring problems im tired of this problem and it will happen intermitnely just wonderin if anyone has had this same problem and has sovled it figured id try asking around before buying a pcm
Old Nov 17, 2006 | 07:46 PM
BigBlue's Avatar
Don't worry about it. It's just something that pops up with fueling boxes that do boost fooling. I've got it on my TST and had it with my comp and I get it with my smarty.
Old Nov 17, 2006 | 08:19 PM
curts99's Avatar
yea but it has absolutly no power when it sets the code is this common
Old Nov 17, 2006 | 09:59 PM
Marks99's Avatar
Interesting - my Bank$ box does that also ... about once a week
I've been blaming it on Bank$ ... from what BigBlue just said I guess it's pretty common (?)
Mine doesn't completely lose power ... it just starts surging, sometimes it clears up on it own ... other times (mostly) I have to clear it with my code scanner.
I too wish there was a way to fix this
Old Nov 17, 2006 | 10:05 PM
scottsjeeprolet's Avatar
double check all of your connections, try leaving the Map unplugged at the block, that's how mine is and no codes, Just smoke
Old Nov 17, 2006 | 10:07 PM
Marks99's Avatar
Lol - and worse than that, I was just getting ready to order an Edge box, to replace the Bank$ box because of this problem ....
Old Nov 17, 2006 | 11:35 PM
curts99's Avatar
marks 99 where your from in nor cal im from nor cal also modesto area yea i do disconnect the map sensor at the block sometimes and the problem goes away but lots of smoke wish the prob could be solved its annoying when you go to stand on it to get out in traffic or get arond someone and it happens juess ill have to live wiht it or do way awqy with the box and do injectors and turbo go to old school tuning without the electronis thanks for all your comments and help i appericate it
Old Nov 18, 2006 | 01:00 AM
Marks99's Avatar
I'm up at the top of the state. Siskiyou county, about 60 miles south of the OR boarder (the real norcal )
I think you maybe right about building power the old fashion way!
I'm hoping though, that the people who build these 'boxes' will figure a way to over come this problem. I still think I'll switch out my Bank$ for an Edge ... my Bank$ box is somewhat out of date ... I do know a few people running Edge with little or no problems.
How often do you throw the P0237 code?
Mark
Old Nov 18, 2006 | 06:36 PM
curts99's Avatar
when ever some times it will be good 4 a few weeks or months sometime 3 to 4 times in a trip or a few times a week
Old Dec 12, 2006 | 07:44 PM
curts99's Avatar
called edge today and told them about my problem and they said to send my module it to them and they will see if their is anything wrong with it and if there is and they cant fix it they will send me a new module i was very happy with their service hopefully this will take care of the problem
lvmknsmoke..
Jan 17, 2025 09:14 AM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
