edge boost elbow
Old Sep 8, 2003 | 05:15 PM
GONZO86's Avatar
edge boost elbow
read this on another sitecant post over there)
Edge boost elbow
"After running the EZ on 3 for a few weeks and looking at 1350* (and backing out), I just installed the supplied boost elbow - was able to pull off the stock hose with factory clamp still on and install the EZ elbow. Should still be able to put the stocker back in using the factory clamp.
EGT temps went down quite a bit - Boost now reads about 33psi and I can just barely hit 1200* but it rises much slower now. Seems to cool down quicker as well. Anyone running an EZ without EGT guage might want to put the elbow in.
I swapped mine from under the truck without touching any stuff up top. Just reached up with a pliers and twisted the hose off at the clamp. Took about 10min."
does anybody know whichy hose he is talking about?
any pics.
__________________
Old Sep 9, 2003 | 08:35 AM
Mopar_Mudder's Avatar
Re:edge boost elbow
Well if you have an Edge EZ you know what he is talking about and their is pictures in the instructions. If not it really doesn't concern you because putting the elbow in doesn no good unless you are feeding more fuel to create more boost.
But any way it is just a small rubber hoes right on the bottom of the turbo.
Old Sep 9, 2003 | 03:21 PM
GONZO86's Avatar
Re:edge boost elbow
THANKS, got my edge on order from e-bay should be in 9/10
just wanted to get everything lined up before i recived it
thanks toyota
dodgediesel
14
Dec 14, 2006 09:54 AM
Hopeto
14
Jun 5, 2003 05:05 AM
w4xtc
May 22, 2003 05:39 PM
hellotbone
15
Apr 19, 2003 03:44 PM
hellotbone
15
Apr 2, 2003 02:54 PM
