e g t gauge wires ?
e g t gauge wires ?
hi
i am installing a autometer e g t gauge and it has 6 wires total
1 white gauge light
2 black grounds
1 red 12v positive
do i wire it so the red wire is hot all the time or just when the key is on ?
ins does not say ???
got the red & yellow for the thermocouple installe also , no prob there !
thank you !!
1 white gauge light
2 black grounds
1 red 12v positive
thank you !!
I've got Isspro gauges so I have an external amplifier box that runs the gauge stepper motor. Anyway I run it so its on when they key is on. I have my lights going to a dimmer circuit.
I don't know of any reason to have the motor portion be constantly on. It would continually read temp from the sender. If you went long enough it would run the battery down so why risk it.
My switched power source is a Painless Wiring bus, its a great product! It uses a key on source to pull in a relay. The feeds to the bus are fused and the branch circuits are fused too. Its a great mod that will keep excess loads off your truck.
Hope this helps!
Hope this helps!
1985cucv
04-20-2010 09:50 PM
GlennRMK
04-23-2008 10:03 PM
HighTen
03-05-2005 11:10 PM
