isspro trans temp gauge can you lengthen the wires
Old Apr 18, 2010 | 01:10 PM
1985cucv's Avatar
i was wondering if you could lengthen the wires off of the transmission temperature sender so that the amplifier box will fit under the dash has anyone done this? thanks
Old Apr 18, 2010 | 03:58 PM
Big C's Avatar
yes you can I've done this lots of times
Old Apr 18, 2010 | 04:08 PM
RowJ's Avatar
Best if soldered and you use same size wire.... to avoid changing the resistance.
Minor lenghtening should not change anything.
RJ
Old Apr 18, 2010 | 07:59 PM
1985cucv's Avatar
ive got some 16 gauge diesel manor says no smaller than 18 gauge and anything bigger is ok so im gonna use 16 thanks for the help
big c where you located?
Old Apr 18, 2010 | 10:47 PM
Spooler's Avatar
I didn't have to lengthen mine at all and my box is under the dash. Not sure why you would need to do such.
Old Apr 19, 2010 | 08:56 AM
NavyDood's Avatar
Same here. Wonder if Isspro made the wiring shorter!?!?!?!
Old Apr 19, 2010 | 08:40 PM
1985cucv's Avatar
well im mounting mine on the passenger side right below the vent next to the radio. it is short no doubt about that so i added some wire and i will install this weekend
Old Apr 20, 2010 | 07:38 PM
Big C's Avatar
I'm in the oak creek area (just south of milwaukee)
Old Apr 20, 2010 | 09:33 PM
1985cucv's Avatar
got ya yeah i travel up there everyday work all around there im from burlington
Old Apr 20, 2010 | 09:50 PM
Chevyboy51's Avatar
I'm a dealer and asked isspro they said it was fine. I just try to use the same size wire and solder it . every one I install is done and no problems
feveree40
Oct 3, 2007 03:59 PM
b.lee
Mar 7, 2007 02:27 PM
csramsey640
Jan 18, 2006 04:31 PM
jwtuc
Jan 24, 2005 09:44 PM
Dufrain
Aug 26, 2004 10:47 PM
