Dyno Numbers with Nitro Methane
Old Feb 6, 2007 | 02:53 AM
Big Blue24's Avatar
Lightbulb Dyno Numbers with Nitro Methane
Well, I just tested out a dyno jet today.
With Comp off, I hit 209/ 383
Comp 5x5, I hit 305/ 596
With Nitro Methane Race Fuel Mix, and Comp I hit 402/ 845
And no, I didn't peg EGT's. On nitro fuel blend I only hit 1480* once.
Old Feb 6, 2007 | 05:33 AM
SMOKNISB's Avatar
It is going to be interesting to see how long that motor lasts. I bet it wont be long.
Old Feb 6, 2007 | 08:13 AM
gunracer1's Avatar
well i have to admit it does sound intresting. how much of a blend did you use?
Old Feb 6, 2007 | 09:45 AM
justinp20012500's Avatar
Where did you find a dyno jet? What model was it?
Old Feb 6, 2007 | 09:47 AM
Mike D's Avatar
Almost 100 hp and 250 lbs of torque! That's impressive.
Old Feb 6, 2007 | 09:59 AM
Don M's Avatar
DTR Advertiser
That is not a good thing to do with your pistons, your injectors, pump, etc.
When it blows up would you mind sending me a piston to hardness test?
Old Feb 6, 2007 | 10:30 AM
Mike D's Avatar
I assume nitro methane will affect the aromatics of diesel fuel? Could the nitro methane be injected via a water/meth system? This would bypass the pumps and injectors? How corrosive is nitro methane on aluminum pistons?
Old Feb 6, 2007 | 12:50 PM
Big Smoky's Avatar
I'd like to see a picture of a piston when it blows as well. Just spray a mild shot of nitrous and save some heartache.
Old Feb 6, 2007 | 12:52 PM
Diesel Doc's Avatar
nitro is very hard on bearings and oil it absolutelly destoys oil and likes to wash bearings so using this on a full time deal would be a bad idea unless you want to change the oil every day.
Old Feb 6, 2007 | 04:56 PM
TheBigNasty's Avatar
So basically he is destroying the LP, IP, and washing the oil off the cylinders, and that's not counting blowby. Weeeeeeeeee!
Old Feb 7, 2007 | 01:11 AM
Diesel Doc's Avatar
yep basically
Old Feb 7, 2007 | 08:10 AM
gunracer1's Avatar
i think it all depends on how much of a mix he is running.
Old Feb 7, 2007 | 10:14 PM
Diesel Doc's Avatar
true but still a bad idea longevity wise
Old Feb 7, 2007 | 11:00 PM
Crimedog's Avatar
I've got a buddy that ran some nitro methane through his Dmax, he put it in the methanol injection bottle. He said it might have hit a little bit harder but nothing too noticable. I agree with the weird sound, his Dmax exhaust had a super dep rumble to it. It was pretty cool... especially because it wasn't mine
Old Feb 8, 2007 | 01:10 AM
Rods's Avatar
I like this guy !!!!!!, BTW with the nitro blend hes usen from r/c mayb 10% to 20% nitro and oil then mix that with alot of diesel I dont c much harm , daily driven yeah after a time but for some dynos, drags or pulls HECK ya ....We'll c on the superflow dyno next month how it reacts
