Dual steering damper
Old 02-16-2018, 12:43 AM
LeftLaneGang's Avatar
I dug around in the old threads a bit, but couldn' find anything, so here we are.
I would imagine some of you guys have stuck dual steering dampers on 2nd gen trucks. Mines a 2002 3500 dually, stock height, 4wd sport (not sure if the sport trim makes a difference). The trouble is I'm having an awful lot of trouble finding one for my rig. I've found lots of 3Rd gen ones that look easily adaptable, but i dont know for sure. I'm also wanting to do a Dodge Offroad steering and trackbar upgrade in the summer, but I don't know if the two will cooperate. Any wisdom or experience will be much appreciated.
Thanks y'al
Old 02-16-2018, 01:22 PM
FlaCracker's Avatar
Go to Dodge Steering Support ? DSS, I got my SkyJacker Dual Stabilizer kit from there. They have it for the 2002 Ram as well. It took care of my DeathWobble as well.
Old 02-16-2018, 03:51 PM
Thanks bud, I'll check that out. I've actually never personally met a dodge truck that has a death wobble. Been in plenty that wander all over, but never a shaker. Can't imagine it's any fun.
Old 02-17-2018, 02:26 PM
SIXSLUG's Avatar
Death wobble is a combination of alignment out and worn parts...not sure a dual steering stabilizer is a permanent fix....just my .02
Old 02-17-2018, 02:33 PM
Doesn' have a death wobble. Never has, and I've never actually seen one in person that does either. It' just starting to have more slack than normal, this is just a bandaid fix for the next couple months til I can get it done right. I'm trying to find a good line on a setup for a 3.75 in axle tube, and whether it'l cooperate with a DOR kit.
Old 02-22-2018, 11:12 AM
FlaCracker's Avatar
Trust me, in my case, it was part of the solution. I replaced everything in my front-end suspension, including the tires, strut bushings, all steering rods, steering stabilizer and new steering gearbox, still had the problem. After I added the dual-stabilizers, problem solved. Worn-out front-end suspension components significantly increases the chances of this event happen, I believe the ultimate culprit and source of the issue is design flaws in the 2nd gen suspension system to begin with.
Since adding the dual-stabilizers, I have not experienced this problem again in over two years.
mercedeezel
13
10-13-2013 12:43 AM
MrKen
02-27-2006 06:00 PM
7mmrum
02-25-2006 09:44 AM
bishgeo
12-31-2004 07:25 PM
tmiller24
01-01-2004 07:19 PM
Quick Reply: Dual steering damper
