Dual 4" Exhuast???
Old Oct 7, 2003 | 11:19 PM
GreyBoy's Avatar
Dual 4" Exhuast???
I really want to run dual exhaust, but I cant run stack (although, that would be awesome!!!) because my shell.
I found a dual system and I was wondering if having dual is better or worse than a single. ???
Thanks,
Sam
Old Oct 8, 2003 | 12:16 AM
Marine's Avatar
Veteran: Marine Corp
Re:Dual 4" Exhuast???
You can go to a Turbo-back exhaust for less than that amount. I got a 4" turbo-back with a Magnaflow straight through muff for 425.00. That was 2 yrs ago. They are plenty cheaper now.
Mike
Old Oct 8, 2003 | 02:51 AM
GreyBoy's Avatar
Yeah, but Im just curious if it improves or takes a way power. I personally prefer the dual pipes!!! Esp when blowing smoke!!!
Thanks though,
Sam
Old Oct 8, 2003 | 11:26 AM
Marine's Avatar
I think any change over the stock system is an improvement granted it allows more flow.
Mike
Old Oct 8, 2003 | 01:40 PM
White00's Avatar
I think I saw that DPP has a new 4 inch dual system with 5 inch tips on their web site now. Whish they had that when i ordered mine!
Old Oct 8, 2003 | 02:31 PM
Gene007's Avatar
I'm not sure the duals would be needed for better performance but on mine I y-d off behind the rear axle. Came off with 3" out of my 4" system then installed 22" X 5" chrome extentions. Smoke out both sides, ;D I can hear the sound better also. 8) One problem :P I had was getting by the spare. Just mounted the tire in the bed.
Gene007
WarWagon
Old Oct 8, 2003 | 05:48 PM
tlea7's Avatar
I had a 4" single system and just installed DPP's dual exhaust (dual tailpipes) I can't notice any power difference, but the sound is awsome, blowing twin clouds of smoke is insane and the look of 2 5" stainless tips tucked under the back is sic.
Tim
ps DPP's system is top quality
Old Oct 8, 2003 | 09:32 PM
MNISB's Avatar
I have done my fair share of design, fabrication and welding.
I'm thinking take two 4" pipes and cut them diagonally. From the mid point at the end and out towards the sides. Do it say over 2.5-3.5 ft of length then weld the two together. So the 4" downpipe would slowly blend into to 4" pipes which would go to a twin inlet/outlet4" perferated core muffler. Either that or twin round 4". The oval with twin tubes would consume less space. From the muffler outlets I will start at 4" and work up to five. CONE engineering would be a good place for long 4-5 (or even bigger if you want) pollished stainless tips. The whole point of good exhaust is to have low restriction and slowly increase tubing size. Going from a single four into a dual 4 beats OE but on a dyno a single 5 might do better. You can go larger than 5 inch but do it gradually to maintain velocity in the pipes then you will see gains.
Old Oct 8, 2003 | 09:44 PM
GreyBoy's Avatar
Thanks for the help guys!!! Im gonna check out the DPP site, but Im probably gonna have a system made.
Thanks,
SAm ;D
PEAKSTRYDE
Oct 11, 2007 04:20 PM
mudder500
16
Jun 15, 2007 07:37 AM
Cruizer
Apr 24, 2007 10:13 AM
1320
Jun 23, 2003 08:05 AM
