dtt tranny acting up
Old Oct 26, 2007 | 04:07 PM
ncdodgeman20's Avatar
hey yall i am needing some advice here i got a dtt trranny that only has 20,000 miles on it andi havent serviced it yet but its acting up really bad at the end of first gear it seems to slip or something its like it wants to shift to 2nd but it wont you have to bout back out of the peddle bout all the way then it will shift hard and sometimes before it shifts you can hold and it fuels to 3200 and dont go nowhere and then it shifts so could anyone let me know some ideas?and it does even with the comp box off so please help.thinks mike
Old Oct 26, 2007 | 04:10 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Not trying to be a joker, but have you contacted DTT?
USA / TOLL FREE # 1-866-504-4002
INTERNATIONAL # 1-604-504-4002
Old Oct 26, 2007 | 07:07 PM
heykw's Avatar
DTT what a joke! they took 5K of my money for a tranny that never worked right. If you live in NC call Jeff Garmon in Griffin GA and he will fix you up right. It's worth the drive
Old Oct 26, 2007 | 07:19 PM
Box5's Avatar
DTT isn't a joke, they have a great rep around here....Sorry to hear u had a bad experience, but thats not the case 99% of the time. Heykw did u call them and try to fix ur problem?
Old Oct 26, 2007 | 08:55 PM
heykw's Avatar
Numerous times over several months It got so bad I was going to sell my truck after speaking to them several times bill informed me that he was not a big shop whatever that meant, I just wanted them to stand behind their product I have never been so let down and displeased by a product.
Old Oct 26, 2007 | 09:05 PM
raychem's Avatar
Do you still have their tranny in your ride?
Old Oct 26, 2007 | 09:18 PM
mysterync's Avatar
Olee poole is in salisbury, He's a DTT and Suncoast man, But theres plenty of shops around, If your having DTT Problems , I would go somewhere that sells DTT Parts. I've heard in some senses that DTT maybe having some issues but cant speak personally , I really prefer suncoast products!
Old Oct 26, 2007 | 09:21 PM
Box5's Avatar
check out dunrite to, there coming up.
Old Oct 26, 2007 | 09:22 PM
heykw's Avatar
I agree go suncoast or go home on a trailer.
Old Oct 26, 2007 | 09:25 PM
mysterync's Avatar
I've heard good things About Dunrite as well!
If you go suncoast , You'll never regret it, Even if the vendor you purchase from wont back somthing up suncoast will! John, Joan and Ernie are some great folks!
Old Oct 26, 2007 | 11:20 PM
Fred Swanson's Avatar
it sounds like something is up with the governor. Check the connections on the voltage regulator while the truck is running, to make sure it's not bouncing around, could be a bad connector.
May also need to put a pressure gauge on the gov test port to see what's up there. it doesn't sound like the tranny has an issue.
Doesn't matter who's stuff you buy, they are all prone to issues with the electronics.
Old Oct 27, 2007 | 07:27 AM
mysterync's Avatar
Dont the Govs. Generaly throw a check engine light?
Old Oct 27, 2007 | 07:50 AM
jkretzer's Avatar
do the recommended service, start by following DTT's instructions of they wont warrenty anything. service interval is 500-1000 miles after initial rebuild. you need to adjust the second gear band since the material on the band does compress some. also check your pressures, that will tell you everything that is going on in that trans. you need to drop the pan.
others- this was started as a "help me" thread not "my auto is best, or i dont like this company BS." lets try to point this guy in the right direction.
Old Oct 27, 2007 | 07:53 AM
AlpineRAM's Avatar
Not really- as long as the sensor is within reasonable limits it won't even throw a code.
(But still mess up shifting to a point where it gets undriveable)
ncdodgeman20: Did you check the usual suspects? Fluid level, color and smell? Electrical connectors (Plug on the tranny and the PCM)? Take a look at the wiring loom (Sometimes it gets pinched or rubbed through).
Does your truck trhow any codes?
AlpineRAM
Old Oct 27, 2007 | 09:31 AM
heykw's Avatar
No I no longer have the DTT tranny in the truck the truck now has a suncoast converter and a all mechanical tranny by Jeff Garmon
