DTR VP44 Powered Trucks
Old Feb 16, 2006 | 08:26 PM
Ph4tty's Avatar
From the sigs on the Ultimate HP Thread and the Proven 500hp Combo thread. I edited tires, suspension, fuel systems,.. for easier reading. My goal is not to make a competing thread to the ultimate HP, but a reference for bombers I also excluded a few trucks that didn't list which parts they're running
Bob Wagner
01 Don Mach4's, DODGEZILLA/14WG, Rips Allied 4 system,DTT 91% tranny, AFE Intake, Marco's Smarty ecm tuner
401hp/833
dodgediesel4x4
2001 HO, 6 speed,Edge Drag Comp, Mach 1.5's, SBC Con OFE, Super B, Scotty Duce, 4 in. straight piped
402 hp/899+
JDGnut
2001.5 DD-DUFM, DDIII's, Clutch from clutch-shop.com,
413hp/900+
Meatball
2002 5-spd, SLEDDIE 66, Industrial Injection injectors, Edge Comp, Scotty II with hole.
416 hp/798
diesel_burner
2002 h.o.nv 5600, mach 1.5, edge comp, con fe
421 hp/941
CTD_Neil
2001.5 HO 6 spd, Drag Comp, DD3's, HTB2 62/12, 4" Exhaust, AFE
434 hp/887
Beast2B
2001 ETH EDM3's, B1-2, MadECM, Edge Drag Comp w/Blue Chip cover,4" exhaust,BHAF w/Mallory mount
434hp/1006
Big Blue
2001 AT 4X4 TST, 100HP Injectors, Smarty, KSB-1, DTT VB
438hp/996
Getblown5.9
2002 ETH AFE stage I, 4" turbo back to 5" stacks, Edge Comp wire tapped, lil 55, DDP 150hp injectors
448hp/822
Tiger Rag
2001.5 2500 6 spd, HO, 4.10 gears, TST pm3, Smarty, BD XXX 155hp Injectors, BD intake, Twins, and ARP studs, 4" Bully Dog exhaust
453hp/865
1/4 mi 15.074 -93.42 mph
More Power
01 ETH 6speed 4x4 Mach 4's Edms, Edge Drag Comp (HTT) HTB2/12 turbo, southbend con ofe 4inch exhaust, 3.55 gears
455.1hp/ 992.8
DTroy
2001.5 3500 Dually 5 spd. 3:55 Axle, 4 x4, Boost controller, Smarty, HRVP, Mach 4's, Blue Chip FMS, Phat Shaft 64, AFE Intake, 5" Exhaust,SBC DD 3850,
463hp/ 893
Mike D
99 2500 CTD 4x4 Auto, SMARTY, TST PM3, F1 Mach 4.5, HTB2/64 Killer B2, Scotty II w/UNI Air, 4" exhaust
467hp/1012
MColeman
1999 4X4, AFE Magnum Force, Mach 3, drag comp, HTB2, DTT 89%, 5 inch exhaust,
471hp /998
12.84@102
Charlie8301
2001.5 Auto W/ 355 Gears, Catcher ECM/TST PM3 stack, Mach 1.5 injectors, Phat Shaft Super 62, Full HTS Trans, w/ Suncoast 91% Triple disk TC
472/990
13.4 @100.4 MPH
MSquare
2002 HO, HTT Killer B2 64/14, Drag Comp, DDP J-48 Injectors, OFE, AFE, DDP 4" exhaust, AFE Magnum
475hp/982
CTD2001
2001, 4x4, 3.55, DTT auto, 5" Miter Stacks, K&N intake, Sledpuller 66, Edge DRAG Comp, wire tapped, ATS Arc Flow manifold, ARP studs, Vp44 pump cover, Mach 6 injec., MAD ECM.
485 hp/1087 ftlbs (W/Mach 6,Mustang Dyno)
Ph4tty
2002 3500 DRW RWD ETH: DD SBC, II HRVP, Phat Shaft 64/14, Mach 4's, Sm4rty/Tst 9/9
before tst:
492hp/976
duke1n's old truck
2002 5sp, Comp, Con-FE, 4", AFE, B1-2, Mach4
514hp/1028
Tiger Rag
2001.5 6 spd, HO TST pm3, Smarty, M6's, BD Twins & ARP studs, II HRVP, & Helix 2
535hp/ 977
1/4 mi 4/15/06: ET 15.074 -93.42 mph
John_P
2002 TST PM3 (Comp) stacked w/ Edge EZ, High Flow Injectors, PDR HX-40
540hp/939
12.90@ 105MPH
mooseman
2001 suncoast auto, mach 4's, Edge Juice/Attitude,ats manifold,62/14 HTB2,
stage 2 w/meth.
542.4hp/1098
Bart Timothy
2001 ETH with HTB2, 4" Jardine exhaust, DD3s, Drag Comp, 30 hp shot of propane, and
Snow water/meth using windshield washer fluid.using an unmodified stcok air box with rubber boot
removed, and K&N filter.
542 hp/????
ctd89-99
1999 Goerend Bros auto, Formula I Cam and Injectors,Drag Comp, II SPS66, AFE intake and 4" Exhaust
565hp/ 1093
Spicyjam
2001 6 speed Edge Drag Comp, FASS, Haisley 8x14 injectors, 4" exhaust, South Bend Con FE, Fire ringed, AFE Magnum Force,Silver Bullet Turbo.
568hp/ 1064
bwillarTQ
2001.5 ETC, DD Mitchell'd 6spd, B1/B2 twins, MACH 5's, Edge Comp, FASS, Snow Performance water/meth injection,
BHAF, 5" straight exhaust
617HP/1200+
RJohnson
02 2500 4x4 89% DTT/Billet, Smarty/TST PM3 Comp, Mach 4's, BD Twin Turbos, Firerings/12mm Studs, H2O/Meth Injection
628 HP/1366
13.13/102.93 mph
Timinva
2000 ETC. Stock 027vp44. F1 injectors, head and cam. Drag Comp. Hx40/B2 Twins.
#2 634hp
Huff nPuff
2001 auto,Kendricks twins, Timinva's DTT trans, Mach 6s, Edge comp drag
636.1HP& 1200 on #2 only
12.11sec @ 111mph
OffShoreracer
2002 3500 Dually 4X4, Auto 4.10, B1 - B2 Twins, Mitchell O-ring&Cam, 14 MM Studs, DTT Full Billet with 1480 Output Shaft, MAD Ecm, TST Comp. Version, TST HR VP-44, Mach 6 Inj, BD 5" Exh, BD RAD
656 Hp
Mike Holmen
2002 PDR HT3B/HX40 twins, ATS manifold, edge drag box, Mach 6, 5in exhaust, PDR race tranny (billet everything),
PDR custom 24v cam, PDR stage 2 head, ARP studs
677hp/1453
Idaho CTD
2002 DTT auto, Mach 6's, Drag Comp, Cam, P&P head, o-rings, and twins.
700.1hp/ 1200+
12.03 @ 114.5mph
pro puller
???? auto,EEP camshaft,Hotrod vp44, Piers twins HX40 & HT3B,mach 6,Edge Comp Drag, Nitrous Express single stage system
DTT Auto, and a bunch of other stuff
650 on #2
701 W/ nitrous
Torque was just shy of 1400
Jetpilot
2002 ETC, F-1 Injectors and cam, DTT, Redline + Comp box, Steroid B-1.
#2: 610 HP
Nitrous: 832 HP
So who'd I miss?
Old Feb 16, 2006 | 08:44 PM
phox_mulder's Avatar
Me.
Stock (fueling wise)
208 HP, 420 Torque
17 second 1/4 at 75mph. (or something like that)
phox
Old Feb 16, 2006 | 09:09 PM
Jetpilot's Avatar
Jetpilot
#2: 610 HP
Nitrous: 832 HP
Old Feb 16, 2006 | 09:39 PM
Timinva's Avatar
DTR Advertiser
Timinva
#2 634hp
N2o ???
Old Feb 16, 2006 | 11:03 PM
Ph4tty's Avatar
Originally Posted by phox_mulder
Me.
Sorry Jerry I started it at 400 =P
Like I said this can be a reference for people to plan their bombs.
Glad we've got some heavyweight contenders stepping in
Old Feb 16, 2006 | 11:12 PM
Originally Posted by Phatboy
dodgediesel4x4
2001HO, 6 speed,Edge Drag Comp, Mach 1.5's, SBC Con OFE, Super B, Scotty Duce, 315 pro comp muds,
402 hp/899+
Meatball
416 hp/798
diesel_burner
421 hp/941
CTD_Neil
434 hp/887
JDGnut
413hp/900+
I'm shooting for 400-450 soon.
I don't see turbo's listed on the two bolded trucks, (unless the DD-DUFM is a turbo?)
are they running on the stock turbo?
phox
Old Feb 16, 2006 | 11:24 PM
Ph4tty's Avatar
phox
Based on their sigs and a quick search through theirs posts yes, but I'll make corrections as necessary. DD-DUFM is a rebranded comp from Diesel Dynamics
Old Feb 16, 2006 | 11:28 PM
I knew that, just had turbo on the brain
phox
Old Feb 17, 2006 | 12:27 AM
getblown5.9's Avatar
you will be able to add me to that list real soon
jr adkins lil 55 gets installed next week, comp get upgraded to drag version shortly thereafter, and then i will be shopping for head studs and 150hp or bigger injectors...gonna be an animal for sure.
Old Feb 17, 2006 | 01:58 AM
Kman9090's Avatar
havent dynoed yet but i think i might have a little bit over 400hp, what do you think?
Old Feb 17, 2006 | 09:23 AM
Ph4tty's Avatar
Look at Meatball- he's got the same turbo and a comp just like you and he's over 400. With those 280 hp injectors I think you'll be looking at 500+
Old Feb 17, 2006 | 11:59 AM
Kman9090's Avatar
Thats kinda what im thinking to
Old Feb 17, 2006 | 12:01 PM
BigBlue's Avatar
Come April first I should be on that list.
Old Feb 17, 2006 | 01:31 PM
Ph4tty's Avatar
Why do you think I chose to start the list at 402??
Gotta beat 402!
Old Feb 17, 2006 | 01:33 PM
hahaha nice one. if i get everything installed this week i may get lucky and get on a group dyno next saturday so ill know my exact power...i know it will be over 450 tho!
