DSS The Steering Stabilizers
Old Mar 14, 2006 | 12:57 PM
RussellT's Avatar
Not at all....
I just posted to clarify.
Russell
Old Mar 14, 2006 | 03:33 PM
atch's Avatar
RussellT
you wouldn't want to tell me what the size of the threads are, would you?
Old Mar 14, 2006 | 04:29 PM
Cummins Freak's Avatar
that stabliizer would it work with my 5" lift on me 2500 4x4 dodge
Old Mar 14, 2006 | 04:34 PM
Gotlift01's Avatar
Oh yeah it'd work wonders on yours........and it is a simple bolt on too
~Nick
Old Mar 14, 2006 | 04:35 PM
atch's Avatar
It should. It bolts under the sway bar and to the steering shaft
Old Mar 14, 2006 | 07:38 PM
phox_mulder's Avatar
Sway bar? what is this?
Mine just mounted to the frame right in front of the steering box,
and there were these holes right there in the frame for it to attach to.
phox
Old Mar 15, 2006 | 02:29 AM
ASTAR's Avatar
phox
I hope you're joking!
Old Mar 15, 2006 | 08:28 AM
RussellT's Avatar
Did your lift come with drop down bracketry for the sway bar ?
The DSS will work if your sway bar is mounted in the factory position - or - if the drop bracketry is at least 3 1/2 inches.
Some lifts supply a 2 inch drop bracket for the sway bar that does not allow enough clearance to mount the DSS. If this is the case the 2 inch drop bracket can be swapped out with a 4 inch drop bracket on a 5 inch lift to get enough clearance.
You can also use different sway bar end links to allow for the lift while leaving the mounting position of the sway bar under the frame rails at factory position.
RussellT
Atch, I don't remember offhand what the thread measurement is, I'll look into my drawings.
But if you like I'll sell you a shaft/nut for $ 189 and I'll throw in the bracket for free.
Regards,
Russell
www.solidsteel.biz
Old Mar 15, 2006 | 12:48 PM
atch's Avatar
What a deal!
Old Mar 15, 2006 | 12:53 PM
Diesel-Dan's Avatar
Ell of a deal! haha.......i got my eye on thoes adjustable Lower Control arms!!!
Old Mar 15, 2006 | 09:04 PM
Nope, have had front and rear sway bars off for almost 2 years.
Absolutely no adverse affects.
I do drive like they are removed though, don't take corners like a madman, and slow down a little more on cloverleafs, but with the heavy springs on these beasts, it hardly rolls at all.
Here it is in testing phase, disconnected and swiveled back trying it out,
did that for a week to make sure,
And here it is totally gone, if you squint you can see it on the side of the garage back there.
phox
Old Mar 16, 2006 | 08:27 PM
RussellT's Avatar
AlpineRAM
If you read this please contact me by email at: russell@solidsteel.biz
I am having trouble PM'ing you for some reason.
Old Mar 17, 2006 | 04:15 AM
AlpineRAM's Avatar
Got your PM 5 times
Thanks for the info, I'll contact Rip.
97dodgeram2500
16
May 19, 2010 05:55 PM
kanuckle head
Sep 28, 2008 12:15 PM
vavtx
Jan 6, 2006 10:39 AM
Jun 5, 2003 09:27 PM
