does tire size affect dyno #s?
Old Mar 20, 2006 | 04:54 PM
LanceD's Avatar
if I was to dyno my truck would I have to put stocker sized tires on it first?
Old Mar 20, 2006 | 04:58 PM
Bobcat698's Avatar
My understanding is that you will put down the most power with close to stock size street oriented tires. The 39" tires are a bit more mass to turn than the stockers
Old Mar 20, 2006 | 05:00 PM
BigGunZ's Avatar
Yes, size will affect the numbers since it affects your gear ratio. A trick I've heard of some people using to get better numbers is to slightly overinflate the rear tires to increase their rolling diameter slightly. That trick is supposedly good for around 5 rwhp on a Corvette. This only works to a point though...you can only increase size slightly before you start to lose power.
Old Mar 20, 2006 | 05:02 PM
Gotlift01's Avatar
What if you re-gear your truck?? Does that help any?
~Nick
Old Mar 20, 2006 | 05:08 PM
TxDiesel007's Avatar
Yup...
they might get you a higher top speed, but to get them turning its simple math, a heavier tire needs more power to turn and will eat up a few more horses than stock tires for that reason...
Rick
Old Mar 20, 2006 | 05:11 PM
~Nick
Speaking from working with jeeps...
Well, watchin that is... If you regear the truck, it will use the power that you already have, but it will get it to the wheels at a much smoother rate per say. Lets suppose, with a jeep you run stock 31's at a 3.55 ratio, for a 35 inch tire, to bring it up to speed and make it feel like it did with the stock tires, you would need like a 4.56 gearing or so..
The gearing will compensate for the tire size gains, and thus it will help you out, but your top end speed will suffer, cause more RPMS with the combination of deeper gears will better suit the power you already have, but they will hurt you on the top end, you will run out of RPMS and speed much quicker..
Like anything else, its a tradeoff..
Tx
Old Mar 20, 2006 | 08:42 PM
600 Megawatts's Avatar
Muted User
On an inertia 'dyno', large tires and/or very heavy large steel wheels can drastically lower your indicated HP and torque. On a loading dyno, while making a steady state pull, or one with a very slow ramp rate, the difference will be very very slight and only as a result of the slightly higher rolling resistance. But if you use a rapid ramp rate on a loading dyno, then it too will indicate greatly lower hp/torque when using large/heavy wheels and tires. Its all a result of the increased rotational inertia of the large tires and wheels. The roational inertia only comes into play when you are either accelerating or decelerating the rotation.
KP
dhughe2
31
Feb 26, 2020 09:48 AM
Hondo
Mar 13, 2006 02:23 PM
v8440
Sep 16, 2005 10:26 AM
Dodgezilla
17
Jul 19, 2005 06:59 PM
HOHN
Jan 26, 2005 03:35 PM
