Dodgezilla
I used to run Mach 3's which were rated 140HP , but since then I've switched to Mach 2.4's which are rated 110HP do ot the summer towing factor.
I tow a 30' 10k+ 5er during the summer months. The Mach 3's may have been too much injector to towing a heavy load so I am playing it safe.
I must say the 2.4's were not much of a downsizing, great power and torque.
I have yet to tap the pump wire (over 2years
I choose to look for larger injectors for added fuel
Don~ puts out a great products
)I choose to look for larger injectors for added fuel
I like the Dodgezilla with the 14 WG housing. But it sounds like I shoulda went to a 40 instead. Overall if I keep the box set to 1X5 I'm ok for the most part, but I'll be adding water to be on the safe side I hope
. By the way I dynoed out at 472 and 1001 with 36lbs of boost on a dynojet at 5029ft. Box set on 5X5 I can hit 1600 REAL quick.
As long as you can control the boost hit when you light the water off you should be fine, at your temps you definately need water.
Jim
Jim
Hey Jim Fulmer, I was thinking about that snow performance stage 2 I think with the varible controller then I could adjust the water to come on at a certian boost at 50% then 100% at WOT right? For the most part I want it for hauling up over the passes in the summer.
JaMan
Mar 7, 2004 05:24 PM
