Does anybody make a FP isolator??
Old May 4, 2004 | 03:46 PM
DRD's Avatar
DRD
that last's ?? Getting sick of changing isolators, might have to plumb it in direct I guess.
Old May 4, 2004 | 03:56 PM
BigBlue's Avatar
Plumb it in direct and put a needle valve on it.
Old May 4, 2004 | 03:57 PM
phox_mulder's Avatar
Just go direct.
It's only Diesel, not gasoline.
Many, many here have years and years on their guages without isolators.
Personally, in case of a leak, I'd rather smell Diesel than Glycol.
I was wary myself until I talked to Rod at Wildcat and he talked me out of the isolator.
phox
Old May 4, 2004 | 05:33 PM
rharveysr's Avatar
I went from an electric FP gauge that was on the truck when we bought it,to an isolator, and now it has live fuel to the back of the gauge. You will or should run a short section of rubber line and also the needle valve shutoff to keep the VP44 from killing the gauge.
With the way the pump pulses the gauge cant handle it. I am running Areoquip lines and fittings with the needle vavle and the gauge needle is rock solid, but also its sensitive to fuel pressure drop...
Rick
jumper
13
Dec 12, 2011 12:19 PM
feets
Feb 18, 2011 06:31 PM
BADBOWTIE
Jul 24, 2008 10:19 PM
bigfish33
Mar 7, 2008 03:20 PM
sterke76MD
Jul 22, 2004 12:28 PM
