Do these numbers sound correct
Old Aug 25, 2005 | 11:35 AM
Iron City's Avatar
Installed a DiPricol boost and EGT gauge (pre turbo) last week. In driving around town I'm getting about 300 on the EGT when cruising. The most I can get it to when accelerating up a hill in 4th gear, or WOT in 3rd is about 650. At this point my boost is about 23 psi give or take 1. The truck is basically stock, except I think the PO moved the fuel plate forward. Do these sound like reasonable numbers? Just want to be sure I installed them properly.
Old Aug 25, 2005 | 11:37 AM
CTD_Neil's Avatar
Those numbers do seem quite low. I'm not real familiar with the 12v's and how hot they run, but still those numbers seem low, seem like post turbo readings actually.
Old Aug 25, 2005 | 11:39 AM
ramtd02's Avatar
I agree, those egt's are definatly at the same level a post turbo egt would be...
Old Aug 25, 2005 | 11:44 AM
CTD NUT's Avatar
I agree, sounds like post turbo readings.....even then, those #'s are still on the low side.......that gauge isn't in Celsius or something crazy like that, is it?
Old Aug 25, 2005 | 11:48 AM
Boatnik's Avatar
I'm running a BD fuel pin, with the fuel turned up a little with a stock 21cm turbo and pushing 1200 degrees towing an 7200 pound trailer on level ground.
Old Aug 25, 2005 | 12:14 PM
TxDiesel007's Avatar
Post..
wayy to low, are u sure ur at the manifold (sorry for the stupid question) or are you on the downpipe?
Tx
Old Aug 25, 2005 | 04:22 PM
Rattlerattle's Avatar
Where abouts did you mount the probe pre-turbo? There is a web in the center of the manifold, it should be mounted forward or preferable aft of center.
Old Aug 25, 2005 | 04:40 PM
pmtg's Avatar
and centered vertically in the exhaust stream
Old Aug 25, 2005 | 05:02 PM
TURBOWINE's Avatar
hey iron city good to see another pittsburgh guy here .my egts climb in mine as fast as the tack mine is pre turbo.see ya around
Old Aug 27, 2005 | 03:09 PM
Iron City's Avatar
the pyro probe is mounted pre-turbo, mounted in the center of the back (towards the cab) side of the flange and about 1.5 inches toward the engine from the turbo flange, basically where the directions from Geno's Garage says to do it. Is it possible that I didn't go deep enough when I was cutting the threads with the tap? I'm on vacation right now but I'll take pictures of the setup when I get back. Thanks for the replies. TurboWine, we'll have to get together and compare notes on these trucks sometime.
Old Aug 27, 2005 | 04:23 PM
600 Megawatts's Avatar
Muted User
Hey IronCity and Turbowhine, yinz guys are the first 'burghers I seen on here !!! I will keep my eyes open for yur rigs when dahntawn n'at. Make sure yinz keep em worshed up n'all...We will all have to get together and crush a few ahurn'cities n'at.....
The only other bombed CTD I ever saw in the 'burgh was a maroon dually with dual stacks and a big TDR sticker on the rear window... was 'at any of yinz guys??? If not, what's yinz rigs look like n'at???? Check out mine in my photo gallery and keep an eye open for me..
Ok, done with the pittsburgheese for now....
As for your post, your EGT's are too low to be accurate, as others have allready stated. Sumptin's wrong n'at Sorry, couldnt help it....
KP
Old Aug 29, 2005 | 11:54 PM
got snow?'s Avatar
Did you drill in too far and push the pyro probe against the bottom of the manifold? Just an idea.
Old Aug 29, 2005 | 11:57 PM
storx's Avatar
why is that to low?.....my twins run 650 cruising and about 900-1000 WOT with no load......
Old Aug 30, 2005 | 12:10 AM
GlennRMK's Avatar
My truck(at 5k elevation) runs 600-800 cruising, most of the time
Can get 1100 WFO
Idle is in the 300-400 range after driving it
Old Sep 1, 2005 | 08:12 AM
Iron City's Avatar
got snow, I was thinking that could be a possibility, but I was very careful when tapping the threads, I kept pulling the tap and checking the depth. It's possible that the tip of the pyro probe is below the middle of the manifold, but I'm sure it's not touching the bottom. Any other possibilities for my low reading (if it is indeed low)?
